Build Threads The place for complete build threads of 1st Gen RX-7s.
My project
Old 10-09-07, 02:15 PM
Norwegian_rotary's Avatar
My project
Some pictures of my project
Last edited by Norwegian_rotary; 10-09-07 at 02:29 PM. Reason: Put in one more picture
Old 10-09-07, 02:20 PM
Lapping = Fapping
Jeff20B's Avatar
Yeah a 20B!
Old 10-09-07, 02:27 PM
Originally Posted by Jeff20B
Yeah a 20B!
off course
Old 10-09-07, 02:36 PM
Say hello to Mr.Wankel
dbragg's Avatar
nice!!
Old 10-09-07, 02:39 PM
TACOCAT
OnlyOnThurs's Avatar
WOW! what rack and pinion did you use??
Old 10-09-07, 02:46 PM
rack and pinion? sorry, but I am from Norway
Old 10-09-07, 03:02 PM
dbragg's Avatar
hes using a FC front subframe
what rearend are you going to use?
Old 10-09-07, 03:07 PM
I am using and rear axle from a volvo 940 Turbo with a dana 30 differentsial.
I have rebuilt the axle with 4 link and wattlink to let i move properly.
The suspension i have on the rear axle is the same as Rx7 FC turbo II, same as I use in the front, Tein Flex with EDFC.
Old 10-09-07, 08:59 PM
I has an emblem
-xlr8planet-'s Avatar
How come is missed this thread???????????!!!!!!!!!!!!!???????
Looks great man, but you will blow up the Dana 30
Old 10-09-07, 09:12 PM
Airflow is my life
Rx7carl's Avatar
Looks good.
Old 10-09-07, 10:11 PM
I will find out:P
Old 10-09-07, 11:08 PM
REW'd FB
z-beater's Avatar
What widebody kit is that? I like how it does not modify the front bumper. Simple and effective all at the same time.
Nice work.
Old 10-09-07, 11:54 PM
Nice work.
Its the same kit that mazda used on their grp B rallycars.
The front fender on the left side is not like the 3 other ones at all, so i have spent a lot of time on it to make it look like the other ones. Used foam and built it like I want it to be. Can post a picture of it later today.
I am going to make me models of this kit, so I can create new ones if i destroying one while driving.
I am going to make it all i Carbon fibre, the fenders, front, rear and the hood is beeing made in carbon fibre.
Old 10-10-07, 12:35 AM
Famous Taillights
FirebirdSlayer666's Avatar
One of the nicest widebodies I have seen for the FB. The 20B in there will be sweet
Old 10-10-07, 12:37 AM
bliffle's Avatar
Looking good!
Old 10-10-07, 02:11 AM
Old Fart Young at Heart
trochoid's Avatar
Can't say I've ever seen that widebody for sale, unless this is the factory kit used on the #7 and #77 cars that Mazda campaigned.. I like the lines on it a bit better than mine.
Keeps us posted on the progress, love to see the finished car.
Old 10-10-07, 03:25 AM
Kerebrus's Avatar
sick body! gotta get one of those.
Old 10-10-07, 04:32 AM
I have never seen it 4 sale anywhere either. but i am a mechanic on a org GrpB rally rx7, so i got the kit from there, i will make molds of the kit so i can make several if i need to..
Makes it more easy for me..
I love the shapes of this kit.
Sure i can post more pictures during the process
The only problem is that this kit demands that you get the wheels more out from the car, about 7-10 cm in front and rear. Or else it will look stupid with the fenders way outside the wheels
Old 10-10-07, 05:32 AM
trochoid's Avatar
I had the same problem with my wideboy kit. Bit it's the widest one I've seen. Even with the 15X7 Epsilons in the front and 15X9 in the rear, the wheels sat in too much. I found a set of SSRs in Japan, 15X9/15X10. With the TII front brake upgrade it moved the wheels out more. Still waiting to buy the Moser axles from ReSpeed so I can mount the rears.
The following link is to my widebody build.
https://www.rx7club.com/build-threads-293/unvieling-12a-bp-widebody-462184/
Old 10-10-07, 05:46 AM
https://www.rx7club.com/showthread.php?t=462184
that looks awsome, looks like its even more wider than mine is..
I love 1.gen with widebody kit...
Old 10-10-07, 10:48 AM
680RWHP12A's Avatar
you are the man!!!!!!
i think your english is good and your car is nice
Old 10-10-07, 11:15 AM
Lapping = Fapping
Jeff20B's Avatar
How did you mount the sway bar to the frame rails?
Old 10-10-07, 11:58 AM
680RWHP12A's Avatar
looks like he made brackets that are threaded and welded them to the framerails, from the pics he posted
Old 10-10-07, 12:32 PM
Lapping = Fapping
Jeff20B's Avatar
Was it a good idea to weld it? I'm doing something similar and the ability to remove it without cutting anything would be nice.
Old 10-10-07, 12:51 PM
the brackets with the treads for the swaybar is welded to the frame, I welded a 4 mm steel bracket here, and then treaded this one, now i can install and remove the swaybar using the same bolt and fittings that it's fitted with on the FC
Quick Reply: My project
