Still no real start.....
Old Apr 8, 2002 | 07:18 PM
coldy13's Avatar
Yeah, shutup kid.
Did the MMO treatment, tried to start it. Idled a little rough and very weakly for about 15seconds, tried to give it any gas at all, stalls. Cranked it again, started, same thing. I plan on doing a compression test to make sure that thats not the problem, other than that, dont really know what it would be, any ideas?
Old Apr 9, 2002 | 09:39 AM
hanman's Avatar
Your description is too general. We need to know what has been done so far.
With this information, I would check for a large vacuum leak.
hanman
Old Apr 9, 2002 | 10:15 AM
coldy13's Avatar
Yeah, shutup kid.
ok, i'll post the full story again. The previous owner was driving to work, and all of a sudden he lost engine power, it slowly died and the engine stopped running after about a mile. It sat for 4 months until i bought the car. I found it had a bad igniter, and i replaced it. Still wont start, tried new plugs, still no, put back in old ones to do MMO, after MMO, still wont start. Where would i check for a vacuum leak? I checked a few of the lines, and they seemed fine. Could it be an apex seal?
Old Apr 9, 2002 | 11:14 AM
coldy13's Avatar
Yeah, shutup kid.
heres a link to a .wav file, i just went out and recorded what it sounds like trying to start, maby it will help.... its about 600k wouldnt let me convert it to mp3 for some reason
http://www.geocities.com/coldy0690/RX7start.wav
Old Apr 9, 2002 | 11:17 AM
85rx7blue's Avatar
NOT GOOD
Old Apr 9, 2002 | 11:19 AM
coldy13's Avatar
Yeah, shutup kid.
huh? which part are you talkiong about, bad link, sound quality, or very bad engine noise? the really weird noise is with me holding down the gas.
Old Apr 9, 2002 | 12:30 PM
coldy13's Avatar
Yeah, shutup kid.
anyone have an idea on whats wrong? on the first cranks, i'm not touching the gas at all. on the last one, i'm holding down the gas while i crank, the let off while ite running, then when i touch the gas again it dies.
Old Apr 9, 2002 | 12:59 PM
coldy13's Avatar
Yeah, shutup kid.
also, when it dies a puff of smoke comes out of the top of the carb (air cleaner is off)
Old Apr 9, 2002 | 01:06 PM
hanman's Avatar
I would start with a compression check. If you have a bad apex or side seal your problems are solved or just beginning depending on how you look at it.
If you need information on how to do a compression test come back and post.
hanman
Old Apr 9, 2002 | 01:09 PM
coldy13's Avatar
Yeah, shutup kid.
i think i know how to do a compression test, take out trailing plugs, screw in comp tester, hold in release pin so you get seperate readings for all 3, watch needle jump. do the same thing on the other rotor, is that right?
Old Apr 9, 2002 | 06:15 PM
coldy13's Avatar
Yeah, shutup kid.
anyone?
Old Apr 9, 2002 | 06:39 PM
Yes, that is correct. What you want to look for is three
evenly spaced needle jumps of at least 90-psi.
Good Luck
Gary
Old Apr 9, 2002 | 07:36 PM
coldy13's Avatar
Yeah, shutup kid.
thanks, but where do i disable the fuel pump at, i think there is a fusable link that i can just pull, but i dont know which one
Old Apr 9, 2002 | 07:55 PM
peejay's Avatar
Old [Sch|F]ool
Without hearing the soundfile it sounds like dead engine. If you have a carbureted model don't worry about killing the fuel pump.
Old Apr 9, 2002 | 08:00 PM
coldy13's Avatar
Yeah, shutup kid.
well it is carb but i already killed the pump found which fuse to pull, and its out. what do you mean by "dead" just that something is bad that costs more to replace than get a new engine? or that apex seals are dead?
Old Apr 9, 2002 | 08:17 PM
Joshua Melton's Avatar
coldy 13 so what's with your car I may ask I just came in
Old Apr 9, 2002 | 08:21 PM
coldy13's Avatar
Yeah, shutup kid.
my first post describes how it went out, and a couple posts down from that is a sound file of it trying to start. sorry, dont really know exactly what you are asking.
Old Apr 9, 2002 | 08:23 PM
Talking J-body
RX-7 TEAR IT UP ANYONE ONLINE TO GIVE ME SOME FACTS
Old Apr 9, 2002 | 08:25 PM
Hey your online Great I have been trying to see if there is anyone out there who wants to talk
coldy13's Avatar
Yeah, shutup kid.
??????wtf??????
Old Apr 9, 2002 | 08:29 PM
My RX7 I just fixed it up
Old Apr 9, 2002 | 08:32 PM
She had some flooding problems I fixed it as to find out how to avoid that problem
Old Apr 9, 2002 | 08:35 PM
I had that car detailed, in that I have 2nd series 1986 Rx7
Old Apr 9, 2002 | 08:37 PM
coldy13's Avatar
Yeah, shutup kid.
oh, mines an '85 gsl(maby only gs) dont really know whats wrong with it...
Old Apr 9, 2002 | 08:38 PM
With your car and all I can guess that you probably tried anything and everything to get your car started right up
