troubles with getting the transmission back in...
Old Sep 13, 2007 | 09:35 PM
nanaimorotard's Avatar
arextu
when you think all the hard work is done finally getting the tools to take of the 54mm nut to get at the flywheel for resurfacing, the biggest problem me and 3 friends have is getting the tranny back into place. one of the guys has done a turbo clutch before on a 2nd gen but the one seems to not to want to go in? we have pushed on teh front of the engine jacket it up from the bottom nothing seems to work. please help!
Old Sep 13, 2007 | 10:01 PM
CrackHeadMel's Avatar
Learned alot | Alot to go
did you center the clutch when it was assmbled?
anything left hanging in the way?
ive had the tranny ceatch on the heatshilding thats behind teh shifter spot before, makign it look like things were jammed, when in reality i was caught on some 22gauge metal..
Old Sep 13, 2007 | 10:07 PM
rotary-guy's Avatar
2jz'd fc
dude im in the same spot, my na was easy but now im doing a t2 and the tranny is heavy as hell, me and my roommate were under the car for a good few hours and still havent gottenit in, good luck
Old Sep 13, 2007 | 10:10 PM
7dust's Avatar
Irregular Here
Don't be a *****.
Old Sep 13, 2007 | 10:12 PM
misterstyx69's Avatar
Retired Moderator, RIP
Loosen the Engine mounts a Bit.then you will be able to Tilt the Front of the Engine UP.the back of the engine Down on an angle.If you get a Piece of 4X4 wood,stick iit between the Engine and the rad shroud(if you have one)Or just get something to Angle the engine so it is Lower at the back..By doing this you can get a "clear shot" of the stud on the TOP of the Back of the engine that Is Sort of a guide to the rest of the Trans.,I hope thet helps..OH,watch and make sure that No wires are Between the trnas and the engine once they are Together!(been there done that!)..good luck,STYX!~
Old Sep 13, 2007 | 10:13 PM
oh,and make sure you tighten the engine mounts back up!
Old Sep 14, 2007 | 05:10 PM
arextu
it went in after like 9 good hours of ******* around.. just have to find the right sweet spot i guess
Old Sep 14, 2007 | 11:07 PM
twistedriver's Avatar
Finally I have LSD
+1 30 min engine bolt in no luck. Tip the motor 5 mins was all it took.
Old Sep 15, 2007 | 12:07 AM
Yeehah!..I like it when I am Right!.haha!..but I had to Learn this one,The Hard Way!.and I had to do it Alone!
Old Sep 15, 2007 | 12:17 AM
Finally I have LSD
Yeah and i had the trans harness crushed between the trans and engine too. My arms are still hurting from rocking and supporting the trans.
Old Mar 5, 2008 | 12:01 AM
arextu
Im also using a tranny from a rx3 so the splines are a bit older and beat compared to a t2 tranny. And this is fitting into a 84 13b 6-port large street. how long will this tranny last? XD
Old Mar 5, 2008 | 07:34 AM
pfsantos's Avatar
(blank)
Styx pretty much said it all - but one more thing. Rotate the engine with a socket on the eccentric shaft pulley very slowly. It'll help the splines of the input shaft and clutch disk find each other.
Th0m4s
Feb 26, 2019 02:04 AM
Junkee
Aug 15, 2015 01:57 PM
Marty RE
Aug 13, 2015 11:19 AM
