Power Steering and Idle
Old Apr 6, 2002 | 11:36 AM
ianbell's Avatar
Yesterday my p/s belt jumped the pulleys and thrashed around a bit before I managed to shut down - it's the right belt, but all the adjustment was used up and I had to buy another 1" shorter to get a good fit.
That's not the problem, though, ever since my warm idle is screwed up, it is still at 750, but instead of being rock steady as before, it almost stalls when I let off the gas and recovers to around 750 and it is lumpy and hunting a little bit.
Would the belt coming off and changing the engine load have screwed soming in the ECU? Should I try re-setting the ECU?
My other thought is that the belt thrashing around has hit and damaged something that would effect the idle, but what? Can't find anything loose or obviously damaged - otherwise the car runs as before with no hesitation.
Bone stock 87 n/a with a cone filter.
Old Apr 7, 2002 | 02:21 PM
ianbell's Avatar
Come on folks, somebody must have an idea!
Old Apr 7, 2002 | 06:06 PM
I wish I was driving!
I doubt it is the ECU.
Try this:
http://www.1300cc.com/howto/how2/dashpot.htm
Sean Cathcart
Skeese
65
Mar 28, 2017 03:30 PM
LunchboxCritter
15
Jan 3, 2016 04:11 PM
LMBTG
Sep 2, 2015 07:01 PM
c0rpse
Aug 25, 2015 11:50 PM
