Hybrid Turbo ?'s
Old Apr 6, 2002 | 02:22 AM
chatch's Avatar
Hybrid Turbo ?'s
Well I've been searching for about an hour on the Majestic stage 3 hybrid. I've read nothin but good things but I have one question. I see that BNR supercars also offer the hybrid upgrade. I think the Majestic one is 650 and the BNR is 675. Anyone know what are the pros and cons of these two?
Thanx in advance for the help.
Old Apr 6, 2002 | 03:04 AM
Jerk_Racer's Avatar
My BNR stage2 T04 housing option is inthe mail back to me. So far dealing with BNR has been nothing short of greatness. Bryan has been keeping me updated every step of the way. Constant e-mail is a good thing when you have a lot of money floating out there. He was very helpful when I needed help deciding which setup best suited me. I obviously don't have the turbo back yet, but up to this point I'll say that BNR is a very professional business. I'll keep the forum updated when I get my toy from them.
jerk_racer@hotmail.com
Old Apr 6, 2002 | 03:08 AM
Felix Wankel's Avatar
Super Newbie
Your turbo looks nice. I saw it one of the times I was there.
I have a stage 1 that he did for me. Its good ****.
Old Apr 6, 2002 | 08:10 AM
RETed's Avatar
That doesn't tell us anything unless we know the specs of the turbo.&nbsp It sounds like a V-trim or H-trim compressor upgrade.&nbsp Someone gonna volunteer to pop open their turbo and measure the compressor wheel?
-Ted
Old Apr 6, 2002 | 09:17 AM
FEDREX's Avatar
"Just Looking".......
I did the Majestic about a month ago. $585 + freight (bought all new gaskets from Mtrix - about $100)
Here's what they did:
1. milled turbine housing and installed a new machined Stage III wheel.
2. milled compressor housing and installed new TO4E-46 wheel.
3. installed used over-sized bearing housing with new bearings and new seals.
4. ported wastegate.
5. cleaned and bead-blasted unit. (looks new when you get it back)
I now boost to 9.5psi in 3rd and 10.5psi in 4th.
After I add Haltech F5 AIC, plumb a 720cc (fifth injector) and set a Profec B to 9psi low, 14psi high I should be at 320+bhp.
I opted for this pkg. because it's considerably less expensive than all the stand-alone gear that requires constant tuning,
Excellent customer service. I'm quite satisfied, in fact one of my local buddies just bought a series 5 turbo and manifold for his '87 and just got it back from Majestic as well. He called Majestic and asked them to pull my file and do to his exactly what they did to mine.
The topend improvement is remarkeable, even at 9-10psi. I'm also going to a 3" exhaust and will probably add a blowoff valve.
If you do a search for Majestic I have posted quite a bit of info a few weeks ago.
Old Apr 6, 2002 | 09:56 AM
RETed's Avatar
That'll barely make 300hp...
-Ted
Old Apr 6, 2002 | 10:40 AM
Turbo Timmy's Avatar
Professional Lurker
What's the biggest hybrids can go? I think you have to shave some off the manifold to get anything bigger to fit, no?
-Tim
-Ted
Old Apr 6, 2002 | 12:49 PM
RETed's Avatar
The 60-1 is the biggest compressor you can fit with the stock manifolds.&nbsp The 60-1 compressor housing will actually hit one of the bolt bungs if you try and clock it the same position as the stock compressor.&nbsp If you loosen and reclock the 60-1 compressor housing just slightly, this should clear the lower intake manifold no problem.&nbsp You'll need to slightly realign the mating hose that goes into the splitter pipe right above it though, if you still have the stock intercooler on top.
-Ted
Old Apr 6, 2002 | 02:00 PM
Super Newbie
-Ted
Mine is an H3.
Old Apr 6, 2002 | 02:28 PM
RETed's Avatar
Originally posted by Felix Wankel
Mine is an H3.
Potential to make 300!
-Ted
Old Apr 6, 2002 | 02:43 PM
Professional Lurker
Is 300 good or bad? I think thats pretty good for the price...
Old Apr 6, 2002 | 02:57 PM
fastrotaries's Avatar
W. TX chirpin Monkey
300 at the wheels or motor? I can't believe only at the motor!
Old Apr 6, 2002 | 03:00 PM
kabooski's Avatar
Laying Down Rotary Law
Hey Tim I can get you a stock turbo flange cast manifold
that will clear ANY SiZE upgrade
$200
Old Apr 6, 2002 | 04:51 PM
FEDREX's Avatar
-Ted
That would also depend on injector duty cycle and boost psi. Using 4 550's and one 720 all peaking at 75% duty cycle should be over 300hp.
I've also been told by the guys at JapTrix that I'll be over 300 when they're thru.
If I only reach 300 I'll still be happy because I didn't need a true TO4, or a E6K, or an exhaust manifold. 375 or 400 hp isn't necessary for me on this car. I'm waiting for a new RX-7 (if it's built) or will get a Supra TT and go nuts.
The tech at Majestic informed me that this compressor wheel (no clip) in conjunction with the Stage III t/w will flow for 320+. In addition, the shop I visited that I'm taking my car to that runs a 10sec FC agrees.
Old Apr 6, 2002 | 07:26 PM
RETed's Avatar
The turbo has the potential to make over 300hp, but you're still using the stock CHRA with the crappy carbon seal.&nbsp The carbon seal will crap it's pants anything over 15psi.&nbsp Sure, at 20psi, the compressor has the potential to pump out 350hp, but the turbo will start puking oil...
http://www.turboneticsinc.com/comp_maps/fig12.html
-Ted
Old Apr 6, 2002 | 08:18 PM
FEDREX's Avatar
-Ted
I'll be happy with whatever 13-14psi gets me. Thanks for the info -
What's CHRA??? (compressor housing....?)
Old Apr 6, 2002 | 10:03 PM
rx7_turbo2's Avatar
Professor D.P
Most hybrids use the same center section so the maximum boost is about the same as the stock one 14 maybe 15 psi. Now with that said I've seen the stock one handle 1.5 bar without a problems as well so...
I have a stock turbo running about 12psi, the car is tuned fairly well and is putting down decent power for the stock system. I did a side by side 3rd gear pull on the highway with Chris Ng. Chris is running the pretty standard hybrid. My car got a bit of a jump, but then his pulled away hard. I mean really hard. It's hard to explain how well it pulled on mine, and it just kept pulling. I rode again in it today and it really pulls very hard all the way through redline the boost never drops off, it was alot of fun. It makes me feel good because I have the same turbo sitting on the floor of my room waiting for me to get my **** together and get it in.
For the type of driving I do I'm not sure I would want much more power than what this hybrid puts down. All in all I am very impressed with what the hybrid does.
Old Apr 7, 2002 | 12:27 AM
BLUE TII's Avatar
Rotary Motoring
OK, I don't know turbos; but am interested in learning since I want a stock upgrade.
Ted, the stock carbon seal wasn't replaced in FEDREX's upgrade in step 3. oversized bearing housings, new bearings and seals?
Also, any idea how much extra $$ for ball bearing option if they are putting in new bearing housing etc. anyways? Thanks, Ian.
Old Apr 7, 2002 | 11:03 AM
RETed's Avatar
CHRA = center housing and rotating assembly
Basically, it's the turbo minus the compressor and turbine housing.&nbsp This includes the center part and the shaft and two wheels.
-Ted
Old Apr 7, 2002 | 11:06 AM
RETed's Avatar
It doesn't matter if it was replaced or not - these stupid seals cannot take more than 15psi of consistent boost.&nbsp Other people will tell you otherwise, but MY experience has been not to run over 15psi of boost.
BB retrofit on the stock CHRA?&nbsp Turbonetics already charges $600 for a SINGLE SIDED BB install...it's not worth the costs to do this on a stock turbo, IMO.&nbsp If you want a BB center, go buy a true BB turbo.
-Ted
Old Apr 7, 2002 | 12:11 PM
Ryde _Or_Die's Avatar
Ok, did you boost that high with a boost controller or no? Can this be done to a stock TII and just keep the boost down until other mods are done? Thanks alot.
Old Apr 7, 2002 | 08:46 PM
Ranzo's Avatar
damn am I slow to posting to this or what? anyway I ran a turbonetics H3 compressor upgrade with 720's in the secondaries and I put 316.9Hp to the ground boosting less than 14 psi. There are better compressors than that out there, and with some mods on the exhaust side you can make more power.
Right now I am running the Knight Sports High Flow turbine boosting .88Kg. I have not dynoed it yet but the G-tech said Ihad 331 Hp.
Old Apr 7, 2002 | 08:49 PM
vosko's Avatar
Just Call Me Terminator!
my upgraded stock turbo off a jspec engine. any comments anyone. car feels faster with it but i don't know specs besides it says garrett and a/r 60
Old Apr 7, 2002 | 09:01 PM
Ranzo's Avatar
although it is a true garrett turbine it looks to be about the same as a H3. It is hard to tell by a picture. If you could take it apart and maybe get a part number for the compressor then you could get a flow map for it to know hom much CFM it flows at what boost. Then let the tuning begin.
Randy....
Old Apr 7, 2002 | 10:09 PM
FEDREX's Avatar
I have NO boost controller. Porting the wastegate is part of what they do. If it's particularly cold, I've seem 11psi in 4th but I take it easy then as I don't want to overwork the 550's. I also don't need another ticket - got one first day I had the turbo installed) Need to wait till I do a couple other mods. I'm also running yellow to green (rich) on my Autometer A/F ratio all the way to redline. Replacing the fuel filter last week made a noticeable difference in gauge reading.
One of my friends has a 10th AE with J-Spec, dp, hi-flo cat and I walk him pretty easily.
Another buddy has a pristine '87 TII 53k miles with RB 3" dp, presilencer, cb boosting 9-10 and I've pulled him too by a smidge and I've got a heavier system and heavier curb weight. We both have 9# flywheels.
