How hot are they suppose to run>
Old Apr 5, 2002 | 07:39 PM
t_mak@mail.plymouth.edu's Avatar
I drove my car with a water temp gauge today. During normal highway driving, I do 195 F consistantly. SOmetimes I go +- 10F, but around 195 is right. City driving i am almost at 210F. Is this something I should be worried about? It was only 50 degree out today. My car had never overheated before, but 210 seems awful high at this point of the year when I was only going through a little stop and go/. What do you guys think?
Old Apr 5, 2002 | 08:48 PM
DC350's Avatar
Rotor Head
Do a search, RETed posted some temperatures. I have no idea how hot my engine is in Farenheight, but i know that stop and go driving the engine runs at about....2/8 of the scale up.
Old Apr 5, 2002 | 11:01 PM
tmak26b's Avatar
hmm if i remember right, you have a 89-91. I thought they only go from limp to med then hard on
Old Apr 5, 2002 | 11:55 PM
RX7145's Avatar
-SE with Mods
When I'm moving the water temp. stays about 188-190' If I stop the temp will go up to 210 when the fan turns on; then goes back down to 190.
Old Apr 6, 2002 | 12:15 AM
86Rx7GXL's Avatar
i just got mine in on my 87 turbo i run about 170 to 180 never really over 180. when its cooler out just drivin it'll be 160.
Old Apr 6, 2002 | 12:26 AM
tmak26b's Avatar
Where do you guys have the sender? I have it in the stock location
Old Apr 6, 2002 | 08:33 AM
RETed's Avatar
210F with the stock viscous fan?&nbsp It's high and on the border on concern, but I wouldn't worry about it unless you start hitting 220F...
-Ted
Old Apr 6, 2002 | 09:59 AM
Wankel7's Avatar
Haven't we ALL heard this
Whats normal and abnormal on oil temps?
Old Apr 6, 2002 | 10:09 AM
RETed's Avatar
http://fc3s-pro.com/TECH/MODS/EL/otemp.htm
-Ted
Old Apr 6, 2002 | 11:37 AM
Yeah it is on stock fan, no electric fan. On the highway, if i am really on it hard. I can hit 210. I wonder why it is running so high, is it because i run a lot more water than anti freeze?
Old Apr 6, 2002 | 12:41 PM
RETed's Avatar
How much more water than anti-freeze?
-Ted
Old Apr 6, 2002 | 01:47 PM
probably 85% water 15% anti freeze. I lost all of my coolant when I installed the gauge. I just filled it up with what I had real quikc. I am going to do a 60/40 anti freeze mix on MOnday when I get hoome. I mount the gauge at the stock location, could it be thre reason why it is reading so high?
Old Apr 6, 2002 | 02:32 PM
RETed's Avatar
It could be...really high water mixtures end up causing localized boiling points which the coolant surpresses.
-Ted
James Knox
Oct 5, 2015 07:56 AM
93FD510
Oct 1, 2015 02:00 PM
pfsantos
Sep 30, 2015 01:29 PM
Jetlag
Sep 29, 2015 06:52 AM
