To those without a catalytic converter
Old Aug 26, 2007 | 04:15 AM
grimple1's Avatar
Turd Ferguson
So I've been driving my newly rebuilt 13b for about 200 miles now and the thing seems to smoke more than I'm used to. I don't THINK it's a coolant or oil leak but wanted to double check with other FD owners without catalytic convertors. Does you car smoke? If so how much and what color?
Old Aug 26, 2007 | 10:16 AM
BoostedTimmy's Avatar
Traitor
I noticed my car smells but not a bit of smoke...
Old Aug 26, 2007 | 10:36 AM
MR_Rick's Avatar
Planning my come back
mine did smoke a bi more when I removed the cats.
Old Aug 26, 2007 | 10:40 AM
Authentikdit's Avatar
My exhaust shoots out more black smoke than usual when I replaced my main cat with a midpipe about a month ago,but then again i'm running pretty rich..But yes,mine does smoke a little bit more.
Old Aug 26, 2007 | 10:53 AM
dgeesaman's Avatar
Rebuilt engines will smoke a lot as you burn off the assembly lube and stuff. I don't have firsthand experience as to how long it will do that though.
Dave
Old Aug 26, 2007 | 02:37 PM
MADDSLOW's Avatar
17 second FD
Mine smoked a bit more after the swap, but I believe it's because of the rich map I am using...
Old Aug 26, 2007 | 03:34 PM
grimple1's Avatar
Turd Ferguson
yeah, it smells like normal exhaust. Just kinda suprised at how much smoke there is. I'm using the pfc base map so it might just be that it's very rich at the moment.
I'll try to grab some pix.
Old Aug 26, 2007 | 08:29 PM
BobfisH's Avatar
RX7 lover
Itll be very rich, and will smoke for a couple hundred miles probably. My car still had abnormal amounts of smoke at 500 miles when i ran it in, but it did have a cat then so it probably held some of the oil in there and burnt off gradually.
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
Robrods64
Oct 2, 2015 07:56 PM
