Max boost 93 octane
Old Apr 4, 2002 | 09:32 PM
sigmaldwarf's Avatar
Max boost 93 octane
What is the max boost to run on a built engine with 93 octane? Lets say with... ported and 3mm seals.
Old Apr 4, 2002 | 09:34 PM
Lost Time's Avatar
Chimera Driver
We need some more info here. Intercooler? Fuel pump? Larger injectors? Short bursts or extended pulls?
Old Apr 4, 2002 | 09:35 PM
Factory ic, factory fp, factory injectors... extended pulls.
Old Apr 4, 2002 | 09:37 PM
lane_change's Avatar
It has begun
12psi.
Old Apr 4, 2002 | 09:42 PM
what would be needed to hit the limits of the factory drivetrain... which I hear is 400rwhp? Is this the right limit? and what would I need?
Old Apr 4, 2002 | 09:43 PM
this is not what could be used... but what is required to do this RIGHT... which is the only way to do it!
Lost Time's Avatar
Chimera Driver
About $15,000 to start.
Old Apr 4, 2002 | 10:39 PM
rjuge's Avatar
this week i'm driving...
to true.
you said you wanted to spend $2k. You probably won't pull 280 at wheels..... Car probably doesn't have 255 any more. How many miles are on the engine?>
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
Snook
Oct 4, 2015 08:47 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
