Power FC Cutting the wires or pulling the pins
Old Apr 2, 2002 | 05:23 AM
insomniac's Avatar
This might be an old question, but what do you guys recommend doing? Cutting the four wires or pulling the pins on the PFC? Will those pins be needed for future use?
Old Apr 2, 2002 | 08:03 AM
Rotary Master
I cut my four pins not the wires
Old Apr 2, 2002 | 12:31 PM
Tom93R1's Avatar
gross polluter
And another related question, I pulled my pins out of the wiring harness, but for the life of me I couldn't remember which of the 4 pins goes in which hole. In a couple years when I get emissions tested again, if they give me a hard time about no check engine light, will I be able to put the old ECU in and have things work fine without the 4 pins? Or will the light come on because EGR not plugged in? That gives me an eve better idea, are those 4 pins only for the EGR? does the EGR have a plug you could just disconnect?
Old Apr 4, 2002 | 02:02 AM
rynberg's Avatar
I think you are confused. You pull the 4-pins on the PFC itself. Leave the wiring harness alone. The stock ecu should plug right back in. BTW, when they check emissions in Cali, they look to see if your check engine light is ON; they don't check to see if it won't operate. I would imagine it's the same in your state.
Old Apr 5, 2002 | 02:39 PM
Qball's Avatar
Comp Yellow Mica
just stick a small needle nose in the pfc dock.. and yank 'em out? or open up the pfc and yank 'em out.
Old Apr 6, 2002 | 09:39 AM
Lost Time's Avatar
Chimera Driver
You're better off doing it from the outside. If you open the PFC and look, you won't be able to easily access the second row. Open it and you'll see what I mean.
Old Apr 7, 2002 | 05:07 AM
Qball's Avatar
Comp Yellow Mica
so just stick in a tiny needle nose into the dock and start jiggling and ripping away? heheh.. i hope i dont break anything important inside... *cross fingers*
Old Apr 8, 2002 | 12:00 AM
Lost Time's Avatar
Chimera Driver
After I pulled the pins out, it turns out there was still enough "nub" left to make a connection. So I ended up having to cut the wires on the harness anyway. Do be careful, it's very easy to disturb the other pins while your jiggling your needle nose in there.
Old Apr 11, 2002 | 02:10 PM
thatoneguy's Avatar
Which pins do we remove. I lost my instructions....
Old Apr 11, 2002 | 02:22 PM
thatoneguy's Avatar
nevermind, I found a page
Old Apr 11, 2002 | 11:51 PM
lane_change's Avatar
It has begun
**** it. Pulling the pins was a hassle so I just cut the wires a couple inches back in case I ever have to sauder them back together. I got my ECU in the car in about 3 minutes. I just pulled the Kick Panel, pulled the old ECU out and unplugged the harness, cut the wires and plugged the PFC in and put the kick panel back on. I then let the car idle for about 10 minutes with no fans then 10 more mis. with the fans on. Idles great, runs great. Awesome performance gains as well.
dkwasherexd
May 27, 2017 04:51 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
Leeroy_25
Aug 17, 2015 12:53 PM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
