Haltech Haltech TPS sensor bracket for REW TB (pics)
Old Jul 9, 2007 | 11:03 PM
ducktape's Avatar
Fast-Trash
I could not for the life of me find anyone willing to part with a TPS pigtail for the stock REW TPS, and I've never once seen an FD in yard. A couple of guys mentioned finding the mystery plug in the wiring harness in a Geo Tracker, but I didn't have any luck. I decided to make my own bracket, and mount the Haltech supplied TPS onto my REW throttlebody. Here's what I came up with:
First I stripped the TB of all elements I found to be unnecessary including:
The stock thermo switch and the thermostwitch actuator on the static arm
The stock bellcrank, replaced with 1/2 of a TII bellcrank. (custom brass spacer)
The (throttle trim?) dashpot and arm
The stock TPS sensor, actuation arm, and baseplate
I then gently filed the inside of the sensor to accomidate the larger bore and installed the sensor against the base of the throttle stop. The sensor is partially actuated in this configuration, most likely around 10-20% throttle which can be compensated for with the Haltech software. Sorry, that's the way it is.
Here's the plate I made from stock aluminum. It's not laser perfect, nor is it terribly exciting to look at. I'll send my measurements to anyone who wants to try to make it.
The sensor installed on the plate.
Here is the whole thing in place.
You can see I spaced out the plate with a couple of 1/4" nuts for time sake. I'll make a couple of spacers for it out of aluminum tube in the next couple of days. Note in the first picture you see one long screw, and one slightly shorter screw... These came from removing pieces of the TPS. The longer screw goes in the top. To mount the TPS, I used aluminum sheetmetal screws.
I'm also likely to space out the TPS with a pair of small washers, as there is a small ridge between the plate and the sensor.
Old Jul 15, 2007 | 09:33 PM
Wankel7's Avatar
Haven't we ALL heard this
Wow, that is really clean!
Old Jul 16, 2007 | 09:51 AM
darkslide750's Avatar
I have an extra tps pigtail. A little late though.
Old Aug 15, 2007 | 12:07 AM
NZ_87_TURBO's Avatar
long live the monster BP
im about to do the same. Whats the bell crank? Ive got a couple of t2 Tbodys to modify so thats ok.
Old Aug 15, 2007 | 10:36 AM
ducktape's Avatar
Fast-Trash
The bellcrank is the arm your throttle cable connects to on the throttle body.
Old Aug 15, 2007 | 10:42 AM
T2 vert's Avatar
Why don't you use the stock TPS? That is what I use and it has been working for a few years now with no problems.
Old Aug 15, 2007 | 12:07 PM
ducktape's Avatar
Fast-Trash
Did you just look at the pictures, and not read the first post at all? The answer is in the first sentence!
Old Aug 15, 2007 | 04:43 PM
slo's Avatar
slo
registered user
I would have sold you a stock TPS pigtail for 5$.
For parts like that contact JAP2LA
Old Aug 15, 2007 | 05:08 PM
thetech's Avatar
****** of disaster
Hate to pile it on but I also have a spare pigtail laying around Install looks clean though!
Old Aug 15, 2007 | 05:17 PM
the same goes for me, but the TB had no tps to start with but the guy who send it to me has included a mean looking bracket with it anyway so i dont need to fab one up.
Old Aug 15, 2007 | 06:03 PM
BDC's Avatar
BDC
BDC Motorsports
Looks good. Does it work? Does it have any slop between 0% Fault, 0%, and 1% when off-throttle?
B
Old Aug 15, 2007 | 10:56 PM
ducktape's Avatar
Fast-Trash
B
Works great, there's no slop at all. Car has been to the dyno and the track, and it's been spot on every time.
Old Aug 16, 2007 | 06:50 AM
C. Ludwig's Avatar
www.lms-efi.com
Think Duck made two or three posts asking for pigtails and no one replied. Turns out 1st gen DSMs use the same style TPS so that's at least one more source for pigtails.
Old Aug 16, 2007 | 11:55 AM
BDC's Avatar
BDC
BDC Motorsports
I'm thinkin' sticky...
B
Old Aug 16, 2007 | 01:39 PM
ducktape's Avatar
Fast-Trash
Yep... https://www.rx7club.com/showthread.php?t=654618
Bumped it for a month, and no one had one for sale. It was holding up my build, so I improvised.
Snoopy FD
Dec 8, 2015 01:45 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
Craze8
11
Aug 14, 2015 06:11 PM
