Inline fuel pressure gauge
Old Jul 8, 2007 | 04:23 PM
jdonnell's Avatar
I was thinking of putting in an inline fuel pressure gauge underhood. Anyone do this and have part numbers, etc. There's like a zillion gauges out there and best I can tell is I need a gauge to read 60psi with a 5/16" T (only found 3/8"T which should be sufficient).
Old Jul 9, 2007 | 03:05 AM
NZConvertible's Avatar
I'm a boost creep...
That'll be fine, since an NA's fuel pressure will be in the 25-40psi range while driving. Get a 5/16" tee, as it's a PITA to squeeze 5/16" hose onto a 3/8" fitting.
Old Jul 9, 2007 | 06:47 AM
RADsRocket's Avatar
If you must use 5/16" on to a 3/8th" fitting, here is a tip.
Dip the end of the hose in very hot water for a few seconds and then it will slip right on. Dip time will vary. Trial and error. Depends on size of hoses and thickness.
Good luck.
Old Jul 9, 2007 | 06:04 PM
jdonnell's Avatar
thanks for info. I did try to find a 5/16" fitting but all I seem to find is 3/8" or 1/2". guess i'll search some more for 5/16.
Liquid filled or not liquid filled. Does this really matter? I would guess liquid filled gauge gives you a more stable reading?
Old Jul 10, 2007 | 06:12 AM
You must be dealing with amateurs. Go to a hydraulic or engineering supply shop.
A liquid filled gauge is totally unnecessary. Since the car will be stationary when you're observing the gauge, there won't be any vibration to absorb. You'd want to clearly see any fluctuations in the actual pressure, as that would indicate a problem.
Old Jul 10, 2007 | 08:05 AM
WadeMCarter's Avatar
Is there a benefit to using a fuel pressure gauge inside the car? Or is it just as beneficial to have the gauge in the engine bay?
Old Jul 10, 2007 | 06:31 PM
jdonnell's Avatar
Good point about the fluctuations. i didn't think about that too good.
You could run a hose inside the car but I wanted to minimize hose length since fuel is involved.
Old Jul 10, 2007 | 07:24 PM
HAILERS's Avatar
HAILERS
JEG'S makes a really fine little fuel gauge up to 100 psi. Liquid filled.
There are ISOLATOR kits that can be bought if you want to run it inside the car.
That JEG'S gauge accepts 4AN hose that can be fitted on that gauge.
The only reason I bought one was to look at the fuel gague under full throttle to see if it fell on it's face or not. Did not.
http://www.jegs.com/webapp/wcs/store...10002_74786_-1
I looked and couldn't find the JEGS fuel gauge I bought. It's there somewhere.
Old Jul 11, 2007 | 07:06 PM
jdonnell's Avatar
Wow, I forgot about JEGS. Thanks! I can spend all day on that site.
Rotospectre
Mar 28, 2018 03:33 PM
Snoopy FD
Dec 8, 2015 01:45 PM
