put power steering fluid in clutch master :(
Old Jul 8, 2007 | 12:29 AM
TweakGames's Avatar
FD pro licensed driver
ssooooooo yaaaaa Miss read the bottle, and put power steering fluid in my clutch master and drove it around for the day....
It worked..... ok I guess..... but the pedal would come up all the way. I went home to bleed it again and thats when I noticed I put PS fluid in...
I emptied it out and put dot 3 brake fluid in, but now it doesn't seem to do anything (move any fluids) when I pump the clutch.
Do you think the PS killed the seals and what not?
I hope napa has the PS master and slave rebuild kits in stock... I doubt it... unless your clutch master and slave are somewhat universal... (used in other cars also)
Thanks
~Tweak
Old Jul 8, 2007 | 12:33 AM
mcgarret's Avatar
***** happens bro. At the worst, you need $100 for a new clutch master and slave. They would need replacing eventually.
While owning an FC, always keep on the sunny side of the street.
Old Jul 8, 2007 | 12:36 AM
TweakGames's Avatar
ok wow um thanks I Guess but .. unless you know what your talking about please dont post. Rebuild kits are $15 for master, and $12ish for slave.....
Old Jul 8, 2007 | 12:39 AM
mcgarret's Avatar
Uh, yes I do know of what I speak, from screwing things up many times for decades.
After 20 years, the bores of the cylinders are scored. I know there are rebuild kits. I also know that there is a 90% chance they will be puking within a month.
Given the choice between new for $100 with 1year warranty and ******* up a rebuild, I choose peace of mind.
Old Jul 8, 2007 | 12:41 AM
TweakGames's Avatar
K
I'm going to try and just replace the master tomorrow morning and see if thats all that needed fixed. I have a turbo parts car, I think the masters are all the same. (I hope at least)
Old Jul 8, 2007 | 01:16 AM
TehMonkay's Avatar
Back in the game
Yeah masters are all the same.
Old Jul 8, 2007 | 12:14 PM
TweakGames's Avatar
Ok, cool I replaced the master and tried to clean out all the PS fluid I could. Seems to be working REALLY good now. We will see if it works good in a few days still.
BTW PS fluid floats on brake fluid.
Old Jul 8, 2007 | 04:55 PM
NCross's Avatar
I have a rotary addiction
why not just bleed them? would that not save the parts?
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
LunchboxCritter
15
Jan 3, 2016 04:11 PM
alphawolff
Nov 17, 2015 05:57 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
