Which ECU to buy
Old Jun 3, 2007 | 10:22 PM
gonzz's Avatar
Which ECU to buy
I am going to sell my Link ECU and go with another ECU. I'm leaning toward the E11. Any issues with the E11 I should think about prior to buying it? Also going with the LS1 coils. Any suggestins? Thanks. Also running the reworked stock twins..
Old Jun 3, 2007 | 11:06 PM
NOPR's Avatar
Rotary Apprentice
theres a sweet group buy going on for the electromotive tec3r right now. check the group buy section. If you can swing the cash for it, its definitely one of the best.
Old Jun 4, 2007 | 08:30 AM
calculon's Avatar
On flats
I run the E11v2 and am very happy with it. I ran it with LS1 coils very easily on the stock twins.
Old Jun 4, 2007 | 05:59 PM
gonzz's Avatar
What kind of power are you making now?
Old Jun 4, 2007 | 10:14 PM
calculon's Avatar
On flats
i never dynoed with the stock twins/6x ls1 coils
i never fully tuned it with that setup for that matter
I'm going to have my car back together and fully tuned by July 7th come hell or high water
rest assured, I'll be posting then
Old Jun 5, 2007 | 01:03 PM
ReZ311's Avatar
KM48 Burnout
Microtech and Haltech are both good. Microtech has an excellent wiring diagram and is more user friendly.
LT-12
http://microtechefi.com/
E11
http://www.haltech.com
Stay away from the Wolf EMS for 20B apps as I am yet to figure it out, and the support sucks big time!
Old Jun 5, 2007 | 01:07 PM
gonzz's Avatar
I just ordered the E11. Will pick it up at Haltech USA in 2 days...
Old Jun 5, 2007 | 01:16 PM
calculon's Avatar
On flats
I think that you'll be happy with your choice. I cant' disagree with Rez when he says microtech is more userfriendly, but having worked with both, I can honestly say, only BARELY, so little so that i would barely even say there is a difference
Old Jun 5, 2007 | 09:20 PM
gonzz's Avatar
Cool, I am also going to run MSD LS1 coils..
Old Jun 6, 2007 | 09:43 AM
calculon's Avatar
On flats
you might want to do a little research before committing on those coils. David Hayes had some problems with those, and I might have too . . . I say might have because I never fully diagnosed my hiccups, I just did a major reconfiguration with too many variables changed at once to properly assess the problem.
You've got some time, so I would try to avoid impulse buying and search around. . .there's a good chance those will be ample for you depending on your goals.
good luck
ryan
Old Jun 8, 2007 | 06:32 PM
gonzz's Avatar
I'll be ok with them. I'm only going to run 12 psi on this engine. I will start the install on Monday so should have it running on tuesday..
good luck
ryan
Old Jun 14, 2007 | 10:28 PM
cosmo105's Avatar
Dta Ems
Has anyone ever used a DTA system?
http://www.dtafast.co.uk/S_100_PRO.htm
Old Jun 14, 2007 | 10:35 PM
enzo250's Avatar
IRS Champion
I don't like them...
Use the E11.
Old Jun 14, 2007 | 11:52 PM
t-von's Avatar
Rotor Head Extreme
Use the E11.
Could you elaborate on why you dislike?
cristoDathird
28
May 30, 2019 08:47 PM
Skeese
65
Mar 28, 2017 03:30 PM
MoTeC
Sep 10, 2015 07:58 PM
Engine stand ready
Aug 14, 2015 10:26 PM
