Tranny update.
Old May 24, 2007 | 06:12 PM
IronMdnX's Avatar
Glutton for Punishment
Tranny update.
After tearing up 3 stock trannys the past 2 years, and patiantly waiting for a solution for the V160 or t56. I decided to go ahead and give it a shot. I'll be using a 2005 GTO T-56. I found a decent deal on one and it arrived today.
Here is few pics of the stock tranny and the GTO w/a 13b RE auto bellhousing and adaptor.
As you can see they are nearly the same length overall and the GTO shifter sits about an 1" farther back than the stocker.
I'll be mounting the transmission this weekend and taking final measurement to adapt my Tilton slave cylinder to the new bellhousing. and order the clutch discs.
I had the engine face of the bellhousing machined down a 1/4" because the t56 input shaft was a little short in this bellhousing. I would still like to find out how deep a FD auto bellhousing is just for comparison.
I'll take more pictures when the tranny is mounted in the car.
Old May 24, 2007 | 06:14 PM
IronMdnX's Avatar
I will be installing an aftermarket shifter in the near future. The stock one is a little sloppy for my tast. this is what I am thinking of when it is released.
Old May 24, 2007 | 08:40 PM
IronMdnX's Avatar
Ok I have the tranny in place. It is a heavy sucker. The shifter is placed just about perfect in the FD opening.
I Measured for the driveshaft and clutch release assembly. I'll end up getting a different slave cylinder. that the one i have.
It has an adjustable install height for push style clutches. and they have a pre drilled adaptor for the Mcleod tranny adaptor plate that i'm using.
Old May 24, 2007 | 10:43 PM
CMonakar's Avatar
rebreaking things
Nice work! Any pictures of it in the tunnel? Do you think it would fit if it was moved 6.5" back? Thanks for sharing.
Old May 24, 2007 | 11:52 PM
GtoRx7's Avatar
Collections Hold
Why would anyone need to move a engine 6.5" back from stock, are you building some crazy supercar for the street? Oh, nevermind.......
Old May 25, 2007 | 06:20 AM
IronMdnX's Avatar
I really doubt it. it was a tight fit to start with. I had to remove one of the tooling setup tabs on the drivers side to get it centered. I'll take some pictures of the tunnel when I make the crossmember / mount.
Old May 25, 2007 | 08:22 AM
CMonakar's Avatar
rebreaking things
Yeah a super bank account destroyer
Thanks.
Old May 25, 2007 | 08:30 AM
calculon's Avatar
On flats
I'm sure a lot of people would appreciate costs and sources for everything except the tranny. I know I would. Great work, and good luck.
Thanks
ryan
Old May 25, 2007 | 09:56 AM
felix_is_alive's Avatar
.........HHHMMM....i just happen to have a 2004 GTO Transmision in my shop just sitting ........damn you iron .....before this i was just wondering .....now i am actually considering this swap
Old May 26, 2007 | 01:26 PM
t-von's Avatar
Rotor Head Extreme
That's actually what I'm currently doing now. Moving mine back for better center of gravity and polar moment.
Old May 26, 2007 | 01:29 PM
t-von's Avatar
Rotor Head Extreme
What exactly has been the common problem with all these tranny's?
Old May 26, 2007 | 02:00 PM
IronMdnX's Avatar
Stripped the teeth off of 3rd gear on 2, and broke the mainshaft on 1. All 3 time were done w/o power shifting just rolling on the throttle to spool the turbo at 17-18 psi.
Old May 26, 2007 | 02:03 PM
IronMdnX's Avatar
I built the tranny crossmember / mount today. It is a tight fit with the 4" exhaust. I'll post pictures of the underside when I get my cammera back on tuesday.
I really don't see it possible to move the tranny back 6.5". The girth is alot bigger then the FD's.
Old Jun 2, 2007 | 08:10 PM
IronMdnX's Avatar
OK it is all installed minus the driveshaft and torque arm that will be here next week.
Cost soo far
Tranny - 1450
Adapter plate - 230
Tilton Slave - 279
Slave adaptor- 99
Clutch disks - 225
Driveshaft - 265
Torque Arm - 295
Shifter **** - 30
Dakota Digital Box 80
VSS & backup connectors from ebay - 22
Energy suspention mount - 25
Like I said before the tilton Slave setup is adjustable and could be used for any "Push" style clutch, not just tilton.
Here are some pics
Slave Cylinder with feed line and bleeder line
Tilton twin disk clutch
Tranny installed with exhaust connected.
Old Jun 2, 2007 | 08:11 PM
IronMdnX's Avatar
All in all not too bad. I cant wait to drive it and turn up the boost.
Old Jun 2, 2007 | 08:17 PM
IronMdnX's Avatar
More info on the tilton release bearing system.
http://www.tiltonracing.com/content.php?page=hydraulic
It used the GM T-5 adapter for mounting.
Tilton's instructions
http://www.tiltonracing.com/ins/98-1110.pdf
Old Jun 3, 2007 | 11:22 AM
CMonakar's Avatar
rebreaking things
Looks great. Can you get me a picture from bottom so I can see how much space is on the sides of the case near the mid section and tail?
Re. the Tilton, I was thinking about using that with my Carbonetics push-type clutch to gain some more clearance on the side of the case, but I don't have much confidence in the stock gearbox, so I decided to table it. Very nice looking piece though. Where did you get the flywheel made?
Old Jun 4, 2007 | 06:49 AM
IronMdnX's Avatar
Unorthodox made the flywheel. If I remember correctly Mazdacomp sells one that fits a tilton / quartermaster.
Old Jun 28, 2007 | 10:53 AM
calculon's Avatar
On flats
Any updates on this? I know I am REALLY interested in your results.
Thanks
ryan
Old Jun 28, 2007 | 11:22 AM
wptrx7's Avatar
Newb Photog
Is that transmission brace strong enough? Nice job so far
Old Jun 28, 2007 | 03:38 PM
IronMdnX's Avatar
The loop under the exaust I used 8" schedule 60 steel pipe. It is .40" thick and strong. plus added an extra peice on either side with the curve back to back. you can kinda see it in the pics. And the pictures don't do any justice anyways.
Old Jun 28, 2007 | 03:43 PM
IronMdnX's Avatar
update:
The past month has been busy. I spent a week in Canada fishing, another in Wyoming gatting ready to start a new project. and then Last week a hailstorm that tore up my roof and siding on my house.
The torque arm is in, I'm just waiting for the driveshaft which should be here anytime. I hope it will be here before the weekend, because I'm going out of town again next week.
Old Jul 2, 2007 | 02:40 AM
gnx7's Avatar
Very cool indeed. Where did you get that shifter for the T56?
For those interested in installing a T56 into their RX-7's with rotaries that are moved back further you can have the shifter position moved forward 4" by running a Viper tailhousing. That also requires the Viper 30T output shaft (much beefier) vs. the stock 26T output shaft.
Steeda (Mustang stuff) makes a shifter handle called a "Tri-Ax" which puts the shifter ball back about 2-3". I would imagine if you flipped it around you could have the shifter move forward as well.
Old Jul 4, 2007 | 11:00 AM
IronMdnX's Avatar
First drive this morning. Shifts fine at 8250 , so I am happy. I modified the stock GTO shifter by cutting off mist of the handle and welding on a bolt to math the shifter handle threads. It will work for now till a few other options become availible. The throw is shorter than stock but not like a true aftermarket shifter.
Gear ratios are great and seem to match the power band well. Now to make time to tune it for more boost.
Old Jul 4, 2007 | 07:15 PM
CMonakar's Avatar
rebreaking things
Excellent! Glad to hear it works at high rpm.
If you don't mind my asking, did you do anything to make sure the input/pilot bearing assembly was aligned properly? From what I've been told that is important, and it seems like the margin for error is very low.
