autox'd for the first time today, looking for advice
Old May 20, 2007 | 06:08 PM
idsigloo's Avatar
Needs more Displacement.
Okay. I've made some hp mods to my car so it's over stock numbers around 270whp with a laggy turbo that doens't reach full boost until about 4100rpms in 4th. Anyhow, I have NO suspension mods other than energy bushings. I am running 235/45/17 goodyear f1's tires. Stock T2 struts/springs.
The problem I'm running into is that I'm getting alot of understeer, or more understeer than i desire or thought i would get with my tires. I am keeping in mind that the track was kind of sandy.
I'm wanting suspension tips for making the car handle better thus I have really no suspension mods before I started so I can tell a difference in the car by doing every little thing.
I do have alittle bit of positive camber which you can tell just from looking at the wheels/tires on the car. Would this positive camber on the front be the cause of my understeer issues? I know that usually when you lower the car negative camber is induced. I went ahead and ordered kyb agx's and rb springs. Would this setup offer me enough negative camber to make a difference or do you all recommend camber plates to accompany this suspension change?
Is there anymore information you need about my car that I forgot?
Old May 20, 2007 | 09:37 PM
Larz's Avatar
Potato Love
Konis will make the car handle like a dream. Crank them down all the way for auto-x and your car will be very neutral handling. Do a custom alignment and dial in some negative camber. It will work wonders.
Old May 20, 2007 | 09:48 PM
Eggie's Avatar
I don't know FCs, but...
YES!
Old May 20, 2007 | 10:11 PM
idsigloo's Avatar
Koni's cost too much, plus the front are just inserts and would require modifications to the stock bottom mounts which I hear are junk and that I should go with aftermarket bottom mounts/tubes. Also I don't know how well they work with the stock uppermounts and I would probably need camber plates anyways and that would cost about a grand plus labor on my part to install. So I'll just stick with kyb's. rb springs ftw.
Old May 20, 2007 | 11:23 PM
Valkyrie's Avatar
Set your tire pressure to 40 psi/40 psi...that seemed to work for me today.
Old May 20, 2007 | 11:41 PM
jkstill's Avatar
Searching for 10th's
Yes.
My miata was pushing. I knew it needed an alignment.
Finally got it aligned before the last autox - the front camber was +0.6.
It is now -1.6, rear is -1.6. No more understeer.
It's actually a little loose this way, but I like it that way.
Old May 21, 2007 | 12:36 PM
Larz's Avatar
Potato Love
I've only had experience with Konis on my FD, that's why I suggested them. I also did racing beat sway bars, which kept the car much flatter. I added the front one first, was amazed at the difference, so I bought the rear next. After that came the Konis. After I settle on an alignment I like (I'm experimenting) I'll go with ground control springs (essentially Eibachs).
Old May 21, 2007 | 07:35 PM
nick812's Avatar
13b P-port on a budget
david you did ok I Hope to have some pics of your car to upload from my GF camera I ll let you know about the post.
Old May 22, 2007 | 06:10 AM
nick812's Avatar
http://pg.photos.yahoo.com/ph/ncw812.../ph//my_photos
The1Sun
Mar 18, 2018 11:08 PM
mazdaverx713b
48
Apr 21, 2016 06:45 AM
Engine Management Forum
11
Nov 9, 2015 01:15 PM
fastrx7man
33
Sep 2, 2015 09:42 PM
20B Forum
Aug 19, 2015 01:47 PM
