Reman or rebuild?
Old May 13, 2007 | 01:30 PM
87FCTurboII's Avatar
EFRX-7
Reman or rebuild?
I just tore into my TII engine. It's looking like I'm gonna need too replace all of the side plates because it sat for a long time with a blown water seal. The engine has 107k miles on it.
So would it be better for me to rebuild that engine or just send in the core and get a reman engine?
Old May 13, 2007 | 01:34 PM
TehMonkay's Avatar
Back in the game
How bad is the rusting?
Put it through a parts cleaner machine.
Old May 13, 2007 | 01:35 PM
phoenix7's Avatar
which is cheaper?
Old May 13, 2007 | 01:41 PM
initial D is REAL!'s Avatar
I heard puting the side housings in the hot tank was not advisable. I got some free used s4 side housings and rotors that I want to hot tank.
Old May 13, 2007 | 01:46 PM
jamespond24's Avatar
Depend if you built it yourself but if not, a reman would be cheaper
Old May 13, 2007 | 02:27 PM
EFRX-7
The side housings aren't rusted, they have a bunch of little blemishes where some of the surface has been eaten away. https://www.rx7club.com/2nd-generation-specific-1986-1992-17/pitting-my-plates-651509/
The one in that thread is in the best shape of all of them.
And the center and front irons have some water damage at the bottom of them. So it's looking like i'm gonna be spending a lot for those. All 3 irons are gonna be around $1000, a rotor kit is near $1000, gasket kit is $300. If the reman were $2500 + $1000 core charge, wouldn't I be getting a better deal with a reman if they use new housings and everything?
Old May 13, 2007 | 05:05 PM
EFRX-7
bump
Old May 13, 2007 | 05:17 PM
phoenix7's Avatar
don't bump unless you don't get a response for a period of 24 hrs. or longer.
Old May 13, 2007 | 05:18 PM
Turblown's Avatar
Turn up the boost
Buy some used irons, for $400 range shipped, and have them ground easy.
Rotary Performance Parts
Old May 13, 2007 | 06:12 PM
EFRX-7
Where's the best place to get used parts?
Old May 13, 2007 | 09:44 PM
InsomniacFC's Avatar
Will drive for parts
Junkyard or the parts wanted section. You could also get a J-spec and rebuild it.
Old May 13, 2007 | 10:05 PM
-=1OneShotNO2=-'s Avatar
F.F.F.F.C UNIT!
if you got the 3k, Id go with a reman. Im in the same boat as you, but im rebuilding it myself because i want porting and i need new housings, doing it my self is cheaper. good luck
Vartok
16
Oct 8, 2015 04:49 PM
musker
Oct 1, 2015 05:58 PM
