Pulsation Damper
Old Mar 25, 2002 | 06:49 PM
PureMdMa's Avatar
1 of 203 94 White PEP's
Pulsation Damper
How much should it cost to get this damn thing replaced? I have recently fallen victim to this dreaded virus. I looked at the shop manual and it looks like alot of labor involved.
Thanks
Jeremy
Old Mar 25, 2002 | 06:52 PM
mightyslash's Avatar
Will Work for Ferrari
Yeah, it's a pain in the ***. The damn thing doesnt cost much (~$120), but the labor is expensive.
Old Mar 25, 2002 | 10:55 PM
PureMdMa's Avatar
Bump
Anyone had it done and remember how much it cost?
Old Mar 25, 2002 | 10:58 PM
Probably like $200-300, depending on the mechanic.
Old Mar 25, 2002 | 11:06 PM
Mahjik's Avatar
Mr. Links
I thought I remembered someone saying it was around $700 total for parts and labor for the job.
As mentioned, you could probably do a search and see what other people have been charged that didn't DIY.
Old Mar 25, 2002 | 11:07 PM
djantlive's Avatar
My mechanic charged me $340 parts and labor, and that's when I had the LIM gasket replaced and the manifolds off. I think it costs more w/o the LIM job.
Old Mar 25, 2002 | 11:09 PM
djantlive's Avatar
Check or replace the injectors o ring while you are doing the job. They are prone to failure too.
Old Mar 25, 2002 | 11:12 PM
$340 for parts and labor? That's hell of a deal. Where did you get it done? Was it done right? You can PM me the mechanic's name and his number if you want. Thanks.
Old Mar 25, 2002 | 11:47 PM
PureMdMa's Avatar
Yeah that 340 sounds good to me too. Where are u located, probably in Cali huh. I would love for it to be around that range. 700 sounds way to high. I will just do it myself if its gonna cost that much.
Thanx
Jeremy
Old Mar 26, 2002 | 02:00 AM
hapa's Avatar
The part is around $120-$170 just for the dampner and the o-ring. The labor involved is intensive, you have to remove the upper intake manifold, throttle-body, intake elbow, coils, fuel lines, coolant lines, vacuum lines, and solenoids. If your going in there you might as well change the vacuum hoses to silicon or viton. Also check your injectors or have them balanced and cleaned by RC. I would definately change the rubber insulators that sit below the primary injectors, and check and or change your injector o-rings. If your decent with a wrench and take your time, you definately can do the job yourself.
eric
Old Mar 26, 2002 | 09:22 AM
Mahjik's Avatar
Mr. Links
Thanx
Jeremy
Make sure you read djantlive's message:
"I had the LIM gasket replaced and the manifolds off. I think it costs more w/o the LIM job"
So $340 is not going to be the price you pay unless you have already done some of the work..
Old Mar 26, 2002 | 09:27 AM
djantlive's Avatar
I guess I got a good deal since my manifolds were off anyway. He normally charges $550 for the job I think. I'm in N Cal. PM me if you need more info.
Old Mar 26, 2002 | 12:09 PM
turbojeff's Avatar
Do it right, do it once
I'm doing this job on a 93 Touring right now. It isn't just a quick job. Like hapa said, you have to remove just about everything off the top of the motor. While your in there do the injector seals and might as well do a vacuum hose job too. There isn't a lot of additional labor once you've gone that far and those things probably need attention soon anyway.
I can't see a shop doing it for $340, $75/hr shop rate where I live...
Jeff
93 R1
87 TII
ls1swap
Jun 3, 2024 03:25 PM
FC_DREAMS
20
Sep 22, 2015 09:43 PM
Steelwheelz
Sep 15, 2015 03:22 PM
