oil pressure
Old Mar 25, 2002 | 06:43 PM
tbone94's Avatar
oil pressure
my gauge reads i have no oil pressure but it picks up as soon as i accelerate....just wondering if i should be worried or not.....or if anyone else had the same prob and how did they fix it....it could just be my gauge or sensor.....
Old Mar 25, 2002 | 06:45 PM
rynberg's Avatar
disconnect the sensor and clean it. If it still doesn't work, replace the sensor. The cleaning will probably fix it though.
Old Mar 25, 2002 | 09:46 PM
ronarndt's Avatar
The oil pressure sending unit is notoriously prone to failure. I replaced mine about a year ago and it is already acting up again- pressure drops real low momentarily, them spikes back up. Pretty sad for a sender that costs over $80. If you can get the fittings to adapt from metric thread to pipe thread, you can put a mechanical gauge in place of the electronic one.
Old Mar 26, 2002 | 12:43 AM
GsrSol's Avatar
Z06 powered FD
You're gonna blow your engine!!!
J/k all of ours suck
Old Mar 26, 2002 | 11:28 AM
SanJoRX7's Avatar
uid 0
Where's the sensor? I'd like to clean mine just for fun since mine is also acting up. What should I use to clean it?
Old Mar 26, 2002 | 11:49 AM
Mahjik's Avatar
Mr. Links
Just below the oil filter I believe (which is why it gets oil spilled on it)...
Old Mar 26, 2002 | 02:55 PM
luneytune's Avatar
I don't think so.
Oil pumps don't fail like this. Its the sender mine did the same thing today - even went negative a little. Turned off the car and back on and voila! pressure normal. Shitty sensors as has been said here.
Old Mar 26, 2002 | 03:21 PM
phatmonky's Avatar
William
Re: I don't think so.
Originally posted by luneytune
Old Mar 26, 2002 | 09:17 PM
ziftar's Avatar
Rotor Head
The oil pressure sending unit is circled in red.
Snoopy FD
Dec 8, 2015 01:45 PM
20B Forum
13
Sep 4, 2015 06:54 PM
andyvideopro
Aug 20, 2015 10:55 AM
