Help wth t-78
Old Mar 25, 2002 | 03:58 PM
IgoSlow's Avatar
Help wth t-78
Does anyone have a problem with their t-78 sitting to high? For some reason my t-78 with the pipes hit the damn hood when closed... Manifold is on tight as well as the turbo... anythought.. suggestions..
thanks
Old Mar 25, 2002 | 05:39 PM
Call 911's Avatar
Move your a/c lines that the housing is hitting. Pop the lines out of the clips, remove the clips, and push/bend the lines down and turn the housing as far as you can counter clockwise. (from the front of the car)
Old Mar 25, 2002 | 05:45 PM
the_glass_man's Avatar
Will u do me a kindness?
Let me use it for a few weeks and I'll let you know.
Old Mar 25, 2002 | 05:50 PM
IgoSlow's Avatar
Thanks.. i'll try tha but i didn't think that the hoses where stopping it that much.. thanks again...
I"ll let you borrow it glass man.. i'll just need a nonrefundable deposit of 3000..
let me know..
Old Mar 25, 2002 | 05:54 PM
Call 911's Avatar
I didnt either but It was just enough!
Old Mar 25, 2002 | 10:05 PM
You can cut the output tube to get more clearance, make sure you have some sort of lip to keep the hose from popping off.
Old Mar 25, 2002 | 10:49 PM
A-Spec Tuning's Avatar
Registered User
Ive installed this turbo kit many times..here are some pointers to gain clearance
1. Move A/C lines
2. Clock the compressor housing
3. Cut the outlet pipe
good luck!
Old Mar 25, 2002 | 11:22 PM
IgoSlow's Avatar
Thanks for all the reply, everyeone has been very helpful.
R-magic
Power FC Forum
18
Aug 15, 2002 10:36 AM
Call 911
Apr 26, 2002 08:54 PM
V8HUNTER
May 10, 2001 06:34 PM
