Simple mechanics tech question.
Old Mar 24, 2002 | 11:12 PM
Bambam7's Avatar
I came, I saw, I boosted.
OK- I don't have a pull scale- but I am replacing a front wheel bearing...
The manual specifies to tighten the bearing preload untill the initial turning force (from a pull scale from off the lug stud) is between .9 and 2.2 lbs.
My question- instead of using a pull scale, can I just hang 1.5lbs from a wheel stud, and adjust preload until the weight is just enough to pull the stud down/rotating the hub?
Should work- I just wanted to check, don't want to damage my hubs!
Dan
Old Mar 24, 2002 | 11:30 PM
Scott 89t2's Avatar
SOLD THE RX-7!
I don't think many people use a scale... just tighten with your hands till there is no play.
Old Mar 25, 2002 | 12:18 AM
DJ!
yea should work, but just do Scott 89t2 said use your hands, it easy! no ******* around with weight and crap!
Old Mar 25, 2002 | 07:26 AM
go_speed_go's Avatar
Tighten with a socket first to make sure everything is cozy, then back the nut off and re-tighten it by hand.
SRTx781
Dec 19, 2015 07:30 PM
demetlaw
Oct 2, 2015 06:22 PM
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
