I smell fuel.
Old Apr 25, 2007 | 05:06 PM
DRTHVDR's Avatar
I smell fuel.
I JUST finished putting my engine and accessories back together and the car is running GREAT. Except one little thing.....
I smell fuel when on high throttle and at the secondary turbo. So basically I smell it when it's on boost.
I checked all the fuel lines and there isn't a leak or split in any of the lines. Is there somewhere I'm overlooking to check? ANY help is appreciated.
Thanks guys
Old Apr 25, 2007 | 05:27 PM
car hugger's Avatar
registered user
Most common failure point on the fuel system in the FPD. I've also read that sometimes the charcoal cannister goes bad and will smell of fuel. Check the FSM on testing thhe charcoal cannister. The FPD is something that should be replaced if you've never done it.
Old Apr 25, 2007 | 06:01 PM
existanzrx7's Avatar
Just Boosting
Check your injector O rings I learned the hard way but I cant really get blamed for it I couldn’t find where the smell was coming from two other shops didn’t ether and the Mazda dealer didn’t ether until it cot I mean on fire. LOL so yea check your O ring
Old Apr 25, 2007 | 06:08 PM
Quickly before your car cooks itself.
Jumper the fuel pump to on and make sure 100% there are no leaks from anywhere in the system. This may mean taking some things apart but better then having no car.
Cheers
mark
Old Apr 25, 2007 | 06:31 PM
jd to rescue's Avatar
If you are certain the fuel smell is only on boost, then in all likelihood the leak is at the secondary fuel rail. You may not have one of the insulators in correctly. The insulators seal at the point where the injector ports of the secondary fuel rail seat into the ports on the side of the LIM. Pressurizing the fuel system will not produce a leak at this point. However, pressurize the system anyway to be sure that there is not some other source of the leak.
Old Apr 25, 2007 | 06:44 PM
DRTHVDR's Avatar
I just replaced some of the clamps on the fuel lines and there is no smell of fuel anywhere near the intake manifold. I can only smell it when I drive the car and get into boost.
Old Apr 25, 2007 | 07:03 PM
^^And that is the only time you will smell it if it is leaking as I described. The fuel is spraying out through the gap between the fuel rail and the LIM at boost. You see, the secondary fuel injectors only operate under boost. They supply the extra fuel to maintain an adequate fuel/air ratio at boost. Consequently, when they do spray and you have a leak at the juncture as described you will smell fuel while driving the car. By the time you get stopped and stick your head under the hood, the sprayed fuel has dissipated. I had this same problem and I am fairly certain that is the source of your fuel odor.
Old Apr 25, 2007 | 07:05 PM
DRTHVDR's Avatar
^^^ Sorry for sounding ignorant but I was trying to make sure that's what you're saying (double chekc). I think this is the issue. I'll check it out.
Thanks SOOOO much. I'll post my findings.
Old Apr 25, 2007 | 07:11 PM
^^Don't feel ignorant, it is not a simple system.
Old Apr 25, 2007 | 08:43 PM
DRTHVDR's Avatar
Oh I know. The whole engine/trans were in pieces a month ago and I put it all in myself. I know a TON more about this car now. Still don't know everything.....yet.
Old Apr 25, 2007 | 08:54 PM
Herblenny's Avatar
DGRR 2017 4/26-4/30, 2017
i'm just curious.. can you smell gas in your oil?
Old Apr 25, 2007 | 09:41 PM
DRTHVDR's Avatar
Nope....Oil is nice and clean.
Old Apr 25, 2007 | 10:58 PM
Specter328's Avatar
NASA TTS Build
I have the same problem, I ordered a new PCV Valve (I think, its the Aluminum check valve) since mine was no longer worked, I heard that it may be a cause of the fuel smell under boost problem. If you don't figure it out, I'll let you how it turned out.
Old Aug 8, 2007 | 10:55 AM
pincusa's Avatar
Just wondering if the check valve or the FPD fixed your problems since I'm having the same probems
ls1swap
Jun 3, 2024 03:25 PM
Aramir
Oct 18, 2015 02:39 AM
jeremyferguson4444
Sep 19, 2015 01:27 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
