Megasquirt Why are my primaries always open?
Old Apr 9, 2007 | 12:26 PM
Sindregutt's Avatar
When i connect the MS(turn it on) the primary injectors are fully open and my engine gets REALLY flodded :S
What can make this kind of error? is it something in the software?
Sometimes the MS also get really wicked. All the gauges get red and some green/yellow.. Doesnt help to reboot or anything so then i have to upload the firmware and start all over...
When this happends the fuelpump starts to switch on and off...
Sindre
Old Apr 9, 2007 | 12:52 PM
T2GTUS's Avatar
Fuel pump pulsing usually is a config issue.
check http://megasquirt.sourceforge.net/extra/faq.html
HTH
Old Apr 9, 2007 | 01:10 PM
Sindregutt's Avatar
i aint getting the fuelpump error anymore, but my injectors are still open all the time when the MS has power..
Old Apr 9, 2007 | 03:17 PM
renns's Avatar
There are two likely problems:
1.) MS hardware problem, such as damaged injector drivers. Check on stimulator for proper operation.
2.) Harness problem - check at DB37 end with meter to see if the injector wires are shorting somewhere in the harness/connector.
Old Apr 10, 2007 | 12:27 AM
Sindregutt's Avatar
Ive done number two. It can be number one but i had this problem befor but it just fixed itself...
Sindre
Old Apr 11, 2007 | 12:06 AM
Sindregutt's Avatar
Ive been doing some research on this problem now.
My v3 card had a shorted Q1(all pins). I swapped the Q1 with the Q5 just to try again. The car fired, ran for 15 sec, stopped and got badly flooded. I measured the Q1(old Q5), and it was toasted..
Question is, how could this happend?
I rechecked my injectors just to clarify that they were high impedance. Bank one wasnt!! Bank two was..
Is this the problem? low imp injectors...
Sindre
Old Apr 11, 2007 | 06:12 AM
renns's Avatar
Yes, that's the problem. The low impedance injectors draw a huge amount of current, causing the failure of Q1. Add some series resistors or swap in some high impedance injectors, fix your MS, and try again.
Old Apr 12, 2007 | 01:37 AM
Sindregutt's Avatar
yep i will use it on my fathers custom 12A since i just had to get the 13b running i used my old microtech..
BLK 93
Sep 28, 2015 01:45 PM
heywier427
Naturally Aspirated Performance Forum
Sep 11, 2015 04:49 PM
