CAS Install?
Old Mar 21, 2002 | 08:34 AM
MikeL's Avatar
CAS Install?
I need to move the CAS from the old engine
(second photo) to the new engine (first photo).
My car is a '87 TII. The '88 manual says:
Turn the eccentric shaft until the leading top
mark (Yellow) is aligned with the indicator pin.
Here are the marks that I have. What should the
pointer be pointing at?:
The '88 manual then says:
Match the mating mark and install the crank
angle sensor on the front housing.
What does "Match the mating mark" mean? Is that
something inside of the CAS? I don't think so
because the manual never says to install the CAS
cover. What are they talking about?
Old Mar 21, 2002 | 11:11 AM
Wankel7's Avatar
Haven't we ALL heard this
Ok, not sure which mark is which. I can not remember which comes first. Yellow or Red. However, when you remove the crank angle sensor you will see the gear. In the gear there are two marks. One looks like a divet and the other is the piece that holds the gear. You want to align the divit with the mark on the shaft of the CAS. Once you have that aligned. Take the cover off like you have done. And note where the metal gear tooth is. Just pick a tooth.
The reason you do this is because the damn thing will move when you slip it in the engine. You need to make sure it dosn't move. That is not in the book.
Good luck.
James
Old Mar 21, 2002 | 04:16 PM
MikeL's Avatar
Thanks James,
I looked for what you wrote about on a spare CAS, I found it and it makes sense. Thanks again!
Mike
Old Mar 21, 2002 | 05:43 PM
HAILERS's Avatar
HAILERS
Visual air:
Old Mar 21, 2002 | 05:55 PM
MikeL's Avatar
Great HAILERS, thanks!
Progress being made with the engine.
RX-7 Guard dogs. They are only 5-1/2 months old.
Old Mar 22, 2002 | 02:58 AM
ReZ311's Avatar
KM48 Burnout
Are those your mechanics Mike? lol
Old Mar 22, 2002 | 02:21 PM
HAILERS's Avatar
HAILERS
I'm gonna come over and steal your car before those puppys get any bigger. Nice pups. Nice fmic.
Old Mar 22, 2002 | 03:57 PM
rx7_turbo2's Avatar
Professor D.P
Hey Mike
So was much work need on that motor? I know you were a bit dissapointed with the porting when you first saw it.
24seven_dada
20
Nov 10, 2018 12:03 PM
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
sinclair7seven
11
Sep 11, 2015 10:15 AM
Enzo1944
Sep 6, 2015 08:57 AM
