Sponsored by: CARiD
Still Having the Stalling Problem
Old Mar 20, 2007 | 01:52 PM
SignalAutoD1's Avatar
I have replaced the injectors all the vacum lines in the car but it still stalls and won't hold an idle. I have no clue what to do now.
Old Mar 20, 2007 | 06:24 PM
cbf246's Avatar
what mods do you have? ecu? tbe? stock turbos? fuel pump?
Old Mar 21, 2007 | 03:41 PM
no compleatly stock all NA stuff st 13b motor
Old Mar 21, 2007 | 06:59 PM
Chuck's Avatar
Sounds like a vacuum leak. You worked the injectors and vac lines. Did you check gaskets at UIM and LIM? Is your TPS in working order and set correctly?
Old Mar 21, 2007 | 09:22 PM
I bought a whole new gasket kit for the car, I new at this what is a TPS?
Old Mar 21, 2007 | 09:30 PM
Sorry I'm reatarted, how do I check the throttle positioning sensor
Old Mar 22, 2007 | 09:47 AM
Chuck's Avatar
Your car is a 1991, that's considered a Series 5 FC. In the Frequently asked questions section of the 2nd Generation forum, there is an on-line factory service manual. Look in the Fuel section and there will be a description of how to check and set the TPS. There are 2 or 3 ways to do this and they have been frequently discussed in the 2nd gen forum. run a search on TPS and you will find a bunch of good information. In my experience I have found that the most reliable way is to disconnect the TPS connector and check the resistance with the motor off. Get it set to approx 1000 ohms and then set the idle. If you find that the car is still having problems, you've at least eliminated the TPS a possible culprit.
toplessFC3Sman
Mar 20, 2018 01:54 PM
The1Sun
Sep 18, 2015 07:13 PM
xXBrendanXx
Power FC Forum
Sep 17, 2015 10:10 AM
REX7&Z32TT
Sep 9, 2015 05:16 AM
Steven_McKinley
Sep 5, 2015 10:48 AM
