dyno tomorrow..
Old Mar 19, 2007 | 02:06 PM
patman's Avatar
Resident Know-it-All
dyno tomorrow..
hey guys my car is finally going on the dyno tomorrow mostly just to get some baseline numbers before i rebuild and port it. Doing one pull at 8psi and 2 at 14psi with some tuning in between. This is on the stock block, af61r, ltx12s.
im hoping for ~450 whp at 14psi, you guys think thats reasonable?
i'll post up the graph tomorrow, unless i make like 178hp or something, then i'll pretend it never happened.
pat
Old Mar 19, 2007 | 03:32 PM
BLK FC3S's Avatar
C088
i'll keep an eye out for it. i have a very similar setup and also am curious.
Old Mar 19, 2007 | 03:50 PM
mirabile's Avatar
i think it is reasonable.Goodluck.
Old Mar 19, 2007 | 03:55 PM
Juiceh's Avatar
Saiga-12 Power!
Yeah, I think if I built a 3 rotor turbo setup and put down less HP than some 2 rotor NA setups I'd have to shoot myself. Just pretending it never happened wouldn't cut it.
Good luck. Keep us posted. Get vids!
Old Mar 19, 2007 | 08:35 PM
felix_is_alive's Avatar
pat
HEHEHEHE...LOL
I WILL ask you tomorow so you better not make crappy horses!! <-----Thats me putting the heat on
Old Mar 19, 2007 | 10:08 PM
gonzz's Avatar
Can't wait for some #'s.. Mine gets tuned by Steve Kan on 5 May
Old Mar 20, 2007 | 02:11 PM
come on ...numbers ...anything??......and dont tell me its 178hp !!
Old Mar 20, 2007 | 02:26 PM
patman's Avatar
well, not quite what i was hoping for, but not 178hp either. I think a bigger exhaust will help a lot, i was making peak boost at 4100 rpm or something, and by 6k it was down to 8-9 psi. It could be porting, but i had flow problems with this exhaust before, so thats what im gonna fix first.
in case you cant see the graph, I made 412 HP/386 TQ at 14.7 psi, (bleeding off to 8, dammit)
at 9psi I made 346/295
Old Mar 20, 2007 | 03:40 PM
just to know , what setup was that , porting,turbo ??etc
Old Mar 20, 2007 | 03:43 PM
RX-Heven's Avatar
I'll blow it up real good
Not bad considering stock ports + a small turbo and what you are describing as a restrictive exhaust.
Sure is running out of breath in a hurry.
Do you have a graph of the torque curve as well?
Old Mar 20, 2007 | 03:49 PM
carx7's Avatar
i'm sure it's posted somewhere... but can you link something that has your relavant mods? No, I didn't search yet Just thought I'd ask
thanks
*edit* oops, should have refreshed before posting.
Old Mar 20, 2007 | 04:26 PM
patman's Avatar
block has never been opened. turbo is af61r.
torque curve is the bottom half of the graph....
link with mods:
http://summersville.10.forumer.com/v...755&highlight=
pat
Old Mar 20, 2007 | 04:40 PM
RX-Heven's Avatar
Just checking my vision
Old Mar 20, 2007 | 11:05 PM
patman's Avatar
so i finally verified that an af61r is definately a slightly modified borg warner s300. which should be good to ~600hp.
next question, what size exhaust should i go with?
the original plan was 4" from the turbo back, then twin 3" catbacks. Anyone think that either straight 4" or even 5" would be better for me? ultimately i plan to make around 750whp after the block is ported and pinned, so i want to build the exhaust once and be done with it....
Old Mar 21, 2007 | 07:12 AM
dude , i dont know how much more power you can make with the stock ports ...they simply scare me , especialy the exhaust ones , they are very restrictive
I think if you opend them .....damn she will scream
Old Mar 21, 2007 | 08:03 AM
patman's Avatar
yeah i know, but when this block comes apart im going to be doing so much **** that im trying to put it off as long as i can. still deciding on dewels vs studs and seal selection, also thinking about coatings and balancing, and port phased rotors... the list is too long i need to either eliminate some stuff or make some more money. anyone know where i can get some green fibrous paper lol.
Old Mar 21, 2007 | 09:29 AM
20B-3Rotor's Avatar
Haltech Dealer
What size is you exhaust right now?
Old Mar 21, 2007 | 09:46 AM
patman's Avatar
mostly 3"
Old Mar 21, 2007 | 11:15 AM
CMonakar's Avatar
rebreaking things
Do you have a compressor map for the turbo? You may be way out of the efficiency range.
Old Mar 21, 2007 | 11:53 AM
20B-3Rotor's Avatar
Haltech Dealer
i have an 5 to 4 inch down pipe with a 3 inch system. It was good enough for me.
Old Mar 21, 2007 | 12:52 PM
patman's Avatar
im getting out of it, but not too far... i'll try to find the map later
Old Mar 21, 2007 | 05:46 PM
patman's Avatar
found it, and after looking at it maybe i am stretching this thing a little too far.
a bigger turbo was part of the plan anyway, im just trying to decide which one. right now im looking at either an s400 or a gt42r. s400 costs like half as much, so thats more likely. i figured the gt series turbos would be dropping in price by now, but they actually seem to be going up. last time i looked, a 42r was 1700-1800 bones from the right place, now i cant seem to find any for less than 2100.
anyone got a dyno of a 20b with an s400?
pat
Old Mar 28, 2007 | 02:30 AM
pluto's Avatar
Nice numbers! It looks like the stock 20B exhaust sleeve is hurting your performance. You can also see the injector staging isn't optimzed causing the dip at 3krpm. If you move to the matrix mode, you should be able to fine tune that area.
Old Mar 28, 2007 | 06:27 PM
patman's Avatar
thanks steve
yeah im working on the secondary injector thing, but I think i may need to fine tune in normal mode a little more before i switch to matrix, especially my temp maps, matrix mode worked well for me on 13b, but seems a little tricky on this motor for some reason. I also have a leaky injector i need to fix before i can do much else... keeping this habit satisfied sure is an uphill battle.
Looks like I will be making a T6 manifold for an s400, so i'll get a new dyno soon after. Also gonna weld a second bung into the downpipe so I dont have to compare MT datalogs with dyno graphs...
The new goal is 500whp on stock ports, soon as i make that i'll pull her apart for porting and doweling or maybe a stud kit. I'll keep you guys posted..
pat
Rotate86
May 18, 2018 02:44 PM
eddierotary
Engine Management Forum
16
Oct 4, 2016 08:22 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
