T78 oil lines
Old Mar 13, 2007 | 10:37 PM
13BNUT's Avatar
T78 oil lines
(Already searched)
Anyone know the size of the fittings for the feed and drain on a T78 turbo.
I checked here but dont know if they have to be an exact size sorry or are they universal. http://www.rx7store.net/category_s/232.htm
Also what size oil feed lines and drain lines and what size restrictor pills is needed. I live right by www.bakerprecision.com and sell all fittings and lines but need the sizes. Please any info would help.
Old Mar 14, 2007 | 05:51 PM
teknics's Avatar
Originally Posted by 13BNUT
(Already searched)
The feed line im using a complete -4AN line with no restrictor, I believe the oil feed thread/pitch on the t78 is a 10x1.25...i could double check for you i have the earl's part number somewhere in my boxes of stuff.
as for the return it's a flange so you're going to need a flange to adapt it to either a -10AN or -12AN line, and youll also need the adapter for the front cover as well.
i'll double check the oil feed thread/pitch tomorrow for ya, it might be 8x1.25 or 10x1.25 i havent ordered that part in a long time lol.
kevin.
Old Mar 14, 2007 | 11:49 PM
13BNUT's Avatar
Thanks teknics what are you using for the for the fitting on top of the front rotor housing (feed)? Are you still using the banjo style bolt or can I use a 90 Degree fitting?
Old Mar 15, 2007 | 02:17 PM
teknics's Avatar
I'm using a an adapter to -4an on the turbo to a 90 degree -4an, and then you could use an adapter and a striaght -4an or a 90 deg -4an on the front housing.
i'll get you the thread pitch and size for both those when i get home (like 3 hours from now)
kevin.
Old Jan 29, 2008 | 11:04 PM
jamespond24's Avatar
I know this is a old thread but I need to know what is an exact thread size for the feeding line.
Old Jan 29, 2008 | 11:22 PM
13BNUT's Avatar
I still havent installed mine yet so I will check. You want the one going into the turbo or on the block itself??
Old Jan 29, 2008 | 11:26 PM
I need the one that's going to the turbo.
Old Jan 30, 2008 | 10:26 PM
Any news?
Old Feb 3, 2008 | 09:48 PM
Anybody running a T78 please help?
Old Feb 4, 2008 | 12:13 AM
I found one.
FD7KiD
15
Feb 26, 2021 10:12 PM
Snoopy FD
Dec 8, 2015 01:45 PM
BLK 93
Aug 19, 2015 03:47 AM
FD7KiD
Aug 17, 2015 11:50 PM
