home depot boost controller...
Old Mar 18, 2002 | 04:41 PM
legendr35's Avatar
anyone have links on how to make one, so I can attempt to build one 2nite? Thanks
Old Mar 18, 2002 | 04:50 PM
Flybye's Avatar
It's never fast enough...
http://www.rotarypowered.com/howtoboostcontrol.html
Here ya go
Old Mar 18, 2002 | 04:51 PM
legendr35's Avatar
thanks
do you need one for precontrol also?
Old Mar 18, 2002 | 05:01 PM
Toadman's Avatar
Nomad Mod
Make a couple full throttle runs in 4th gear and start closing the valve slowly after the turbo switchover
Well this sound interesting.. one hand on the wheel, the other twisting the valve, and an eye on the boost guage.
Old Mar 18, 2002 | 05:51 PM
jpandes's Avatar
Re: home depot boost controller...
I just did this last night. Works Killer! Now I am thinking about doing the same procedure to the Pre-control valve to try and get more boost on the first turbo and less spiking. Good luck. Don't forget to buy beer before you start.
Old Mar 18, 2002 | 06:17 PM
GoRacer's Avatar
Speed Mach Go Go Go
Mines in the engine bay
Was put there to keep me from overboosting. It also has two sperate valves things, so I crank the boost on the 2nd turbo to make it non-sequential and it spools instantly!
I've seen the valve in the ashtray before and that looks trick. If you have self control, that would be a nice setup.
There is a real mechanical twin turbo/sequential boost control on the market but can't remember where I saw it.
Old Mar 19, 2002 | 02:53 AM
DRAG0NEER's Avatar
I also did it this past weekend and it's da bomb! Although I'm now running slower (due to lower/safer boost settings), but no more of that annoying fuel cut!!!
radiantRX-7
18
Sep 15, 2015 07:04 AM
vmerino
Sep 5, 2015 11:26 AM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
