Chargecooler
Old Mar 16, 2002 | 04:29 PM
RAZZOR's Avatar
Question Chargecooler
Anybody using a charge cooler on thier FD ?
I've been told its better than a inter cooler.
Old Mar 16, 2002 | 04:36 PM
7sweetie's Avatar
Pilots are hot!
i've read about them, and all them have been used on a piston engine. it stops the pre-ignition of the air/petrol mixture in the cylinders. supposedly cools air down in less than a second
Old Mar 16, 2002 | 04:47 PM
RAZZOR's Avatar
I can understand the logic in it ,water would dissapate heat a lot quicker than air and the biggest benefit would be low speeds aswell as standing still.
could make one out of the stock IC.
Old Mar 16, 2002 | 08:49 PM
suganuma's Avatar
no
chargecooler same thing as air to liquid IC?
hannah, all intercoolers "stops the pre-ignition of the air/petrol mixture in the cylinders"
predetonation = preignition...knock, etc
youve probably heard people say pre-detonation more often than pre-ignition. and the "air/petrol mixture" youve probably heard more commonly refered to as air/fuel mixture......its all the same thing, but how you say it makes you sound smarter i suppose...
if it is simply an air to liquid IC then there is at least one FD i know running the "typical" mods, but with an air to liquid IC instead of the typical air to air type...
scotty R
Oct 19, 2012 07:02 PM
Grant M
Sep 10, 2012 11:08 PM
Longshoe
Dec 5, 2007 12:54 PM
BuckyFD3
Power FC Forum
Apr 27, 2006 01:03 PM
RAZZOR
May 8, 2002 02:16 PM
