Megasquirt Im confused :D
Old Feb 15, 2007 | 05:55 AM
grinder's Avatar
Im confused :D
Hiya chaps
its my first post in here so bear with me
i have sourced a Built Megasquirt - but its in a FORD ecu casing
so ..
1 - would the megaquirt work on a rotary ( i take it that its just the map that changes )
2 - how would i put this in a rotary - would i need to remove the PCB and put it into a RX7 ecu casing
i know its a vague post - but any answers would help
Stu
Old Feb 15, 2007 | 12:35 PM
muythaibxr's Avatar
MegaSquirt Mod
Have you read the FAQ at the top of this section?
That will tell you all the hardware modifications that you need to make, and goes over a lot of the software setup too.
If you have any questions after reading that, post here again and we'll answer them.
Old Feb 15, 2007 | 01:46 PM
grinder's Avatar
cheers - will have a nosey
Old Feb 15, 2007 | 01:55 PM
grinder's Avatar
hummm i wonder why its in a FORD ECU box then ?
so all the boards are the same then - that makes life easier
from what i understood ( not a lot ) - it looked like they had wired it into the box - unless they have ?? - using the loom onto the back of the ECU pins - interesting thoery
im just wondering how much work it would be to convert back to a rotary
what im guessing
1 - get the board out
2 - stick it into a box
3 - do a lot of reading ( about the LED's for the coils etc.. )
4 - test on PC via software
5 - install on car
coool - sounds like a good plan
Stu
Old Feb 15, 2007 | 07:43 PM
renns's Avatar
Unless it's free or near-to-it, leave it for another Ford owner. Go and buy yourself a V3.0 MS1 kit from one of the many vendors listed on msefi.com, and build it yourself. There's few that have regretted taking that approach.
Old Feb 16, 2007 | 04:25 AM
grinder's Avatar
im hoping to get it for less than £20 to be honet
Captain Hook
13
Oct 4, 2015 06:35 PM
FC3S Timmy
Oct 2, 2015 08:08 AM
c0rpse
16
Sep 25, 2015 11:33 AM
doritoloco
Sep 5, 2015 12:41 PM
