Power FC How to make your knock/injector warning light work!
Old Feb 2, 2007 | 05:24 PM
DaleClark's Avatar
RX-7 Bad Ass
OK, sat down and wrote a how-to on this sucker today. Right click and save as to your PC -
http://www.clubrx.org/media/pfc/pfcwarn.pdf
Let me know if any parts aren't clear or something is wrong and I'll revise the document.
In a nutshell - you add another wire to the stock wiring harness, and tap it into the Check Engine light. With this done, the PowerFC will blink the Check Engine light if you have excessive knock or excessive injector duty cycle. Works just fine on my car. This adaptation is necessary since the Japanese cars (for which the PFC was designed) have a different warning light system.
This is quite handy, as it's easily in your field of view when driving - you'll know when to let off if you're seeing too much knock.
Enjoy,
Dale
Old Feb 2, 2007 | 05:43 PM
cewrx7r1's Avatar
Eye In The Sky
Question
I went to the FD forum, followed the link to where the FSM is posted as a zip file,
downloaded it, went to section F and found the B-1b diagram,
and there was the EL Unit and pins labeled.
Did all of this even though I already have the original manuals from Mazda.
Why, to show that Dale gave all that was needed.
"So easy even a caveman can do it."
Old Feb 2, 2007 | 05:44 PM
HDP's Avatar
HDP
A Fistfull of Dollars!
Is the diagram you drew of the ELD connector from the wire side or the pin side?
Old Feb 2, 2007 | 05:49 PM
DaleClark's Avatar
RX-7 Bad Ass
Wiring diagrams are always from the wire side.
Yeah, it was already documented, but it was scattered about, and I wanted to put it all together in one place for posterity.
Dale
Old Feb 2, 2007 | 06:01 PM
HDP's Avatar
HDP
Could the O/B wire be backed out of the ELD harness and connected directly to the wire coming from the 1V pin? It would be easier to connect it like that than trying to strip back the insulation.
Old Feb 2, 2007 | 07:02 PM
Noxlupus's Avatar
Dale, you are the man! I don't care what HDP says about you!
(Haven't we been here before?)
Old Feb 2, 2007 | 07:17 PM
HDP's Avatar
HDP
Old Feb 2, 2007 | 07:31 PM
DaleClark's Avatar
RX-7 Bad Ass
Seriously doubt it - that wire is WAY too short going into the ELD box, and the pin is most likely different, since it's a different connector style. Not to mention how impossible it would be to pull that pin out of the ELD connector - that sucker is WAY buried in there.
Dale
Old Feb 2, 2007 | 07:35 PM
HDP's Avatar
HDP
Dale
I have a way I can connect it, I just need to know if removing it from the harness will matter.
Old Feb 2, 2007 | 10:04 PM
DaleClark's Avatar
RX-7 Bad Ass
Hey, if it'll work, go for it . Shouldn't matter if you pull it from the ELD box.
Dale
Old Feb 2, 2007 | 10:32 PM
ReadyKW's Avatar
Great info Dale. If I understand correctly from the other threads, this mod will also flash the CEL when the ignition is turned on (to appease the Smog Gods), correct?
Old Feb 2, 2007 | 11:00 PM
DaleClark's Avatar
RX-7 Bad Ass
Correct. Light comes on with the key to On position, car not running, then goes out about 1-2 seconds after engine start.
Dale
Old Feb 3, 2007 | 12:51 AM
woundup7's Avatar
The Outsider
So say if I want to add a light to my car, to make up this warning system. I have an 82 FB, The output from 1V is a negative, the ecu grounds this wire out. Is this correct? So I would just wire the other side of the aftermarket LED or idiot light, to a key on, positive wire.
Thanks
Old Feb 3, 2007 | 08:52 AM
DaleClark's Avatar
RX-7 Bad Ass
In theory - I'd check the output with a multimeter to see if it's 12v or ground, that's the best way to be sure.
Dale
Old Feb 3, 2007 | 09:36 AM
badddrx7's Avatar
All Spooled Up
Correct - use a 1.4watt bulb like the stocker is. One side is 12v ignition, other side connect to 1V from the pfc.
Idiot light circuit is fed from the "meter" 12v ingintion circuit on one side. The O/B wire has to be the ground.
tom
Old Feb 5, 2007 | 09:49 AM
Herblenny's Avatar
DGRR 2017 4/26-4/30, 2017
Grrrrreat! write up Dale!
I might have to give this a try?
Old Feb 19, 2007 | 02:39 PM
NissanConvert's Avatar
Please somebody help!!!
trying too hard
I don't have any probes so i'm using a set of "precision" screwdrivers to try to lift that tang and pull the connector out.
It isn't working.
I've tried lifting with one and pushing with another. lifting and pulling with my teeth. burying my face in the housing to see whats going on and trying. This is rediculous.
Old Feb 20, 2007 | 09:51 AM
HDP's Avatar
HDP
It isn't working.
Use a heavy-duty safety pin or hat pin.
Old Feb 20, 2007 | 10:27 AM
It's sorted, i broke it. At least 5 or 6 of the connectors were salvagable, which is good because i broke two of them trying to get them to go into the 7 harness.
The one that i pulled out of the 626 had two little (tiny) metal tabs on the bottom that i had to break off but then it slid right in.
It's a lot easier to use these connectors on the orange and black wire than to solder. just slide your jumper wire in one side influence the orange and black wire in the other and crimp- done.
Old Feb 21, 2007 | 03:07 PM
GtoRx7's Avatar
Collections Hold
good write-up!
Old Jan 29, 2022 | 06:32 PM
LateBraking's Avatar
Sorry for a super necro-bump but, wondering if anyone still has a copy of this PDF in the original post? I know I'm late to the party but I just recently got my FD and I'm looking into this.
Thanks fellas!
Old Jan 30, 2022 | 10:20 AM
j9fd3s's Avatar
Community Builder
Thanks fellas!
its pretty simple, the JDM cars have the exhaust overheat light where the US car would have the check engine light. the JDM cars have no check engine light. so what you need to do is run the ecu's exhaust overheat output to the US cars check engine light, and then the ECU's warnings will light up the check engine light.
you should double check this (there are some other threads), but pin 1V Overheat Lamp on the ecu needs to go to pin 1F on the car
Old Jan 30, 2022 | 11:51 AM
Thank you, I ended up finding the document in some random archive on Google after spending like an hour searching this forum and other sources. I just know people are always told to search and not for our lack of trying, but a lot of links and resources seem dead now, and the pioneering members seem to have gone inactive. Makes me a bit melancholic thinking this reflects the state of rotaries now.
Anyyyyways, I'll re-upload the document in this post, should anyone else be searching the forums and stumble upon expired links as I did.
File Type: pdf
Old May 11, 2022 | 08:30 AM
Rub20B's Avatar
Exhaust Manifold Leak
Could it be if the PFC sees no MOP connected it keeps this light on? The car is an S4 so it has mechanical OMP. When I test it by lowering the knock limit it starts to blink so from wiring side its all correct.
update: after some reading it was clear the PFC does have pretty good diagnose of the OMP and puts the light on as soon as the VMOP is a bit away from its setpoint. therefore fooling it with a resistor like one could do on the fuel temp sensor does not work. I saw no other solution than to invert the signal as the PFC does still flash the light on a inj/knock warning. I just used a simple 2n2222 transistor and hooked the pin 1V to the base. From the base also a 1kOhm pull up to the 5V and then the collector goes to the wire from the warning light and the emitter goes to a ground.
Now when the PFC wants to keep the light on because of the missing OMP it grounds pin 1V and then there is no voltage/current going to the base of the transistor. When the PFC flashes the light it will briefly let pin 1V loose from ground and then the pull up resistor feeds a current into the transistors base and pulls the collector to ground and the light will blink.
Old Dec 29, 2022 | 04:13 AM
Bret Maddison's Avatar
Newbie
Haltech elite.
I am trying the same idea with a s8 and using a haltech. So stand by.
if anyone would like to chime in who has done this,
There is a wire on the OEM harness, (4ai ) service code output signal. I will start there.
The haltech will either have active state as ground, inactive as internal pull up to battery voltage ( or inverse )
So this is very different from a power fc
Carpsycho
May 2, 2014 05:37 PM
**BETSY**
Power FC Forum
Jul 25, 2008 10:01 AM
DaleClark
Power FC Forum
53
Feb 4, 2007 07:25 PM
fritts
Far East Forum
Jan 21, 2007 08:05 PM
GsrSol
11
Dec 2, 2001 09:35 PM
