ryenberg damon anybody quick q?
Old Jan 31, 2007 | 03:13 PM
njstreetrx7's Avatar
17x8 and 17x9 (+37 ff and rr )was very rare to find any posts on anyone running this setup . but what is the widest tire i can fit in rear and front i wanted 235 and 275 is this possible...and of course i will clip or roll fenders w this setup. but what is the widest i can go with? thanks!
Old Jan 31, 2007 | 03:20 PM
rynberg's Avatar
Why are you asking me? Didn't you side against me along with the driftards in the other wheel fitment threads? Why don't you ask the "experts"?
If you really want my opinion (based on performance), you could run a 235/45 17 up front with rolled fenders. You could run a 255/40 or a 265/40 17 at the rear. A 275/40 17 would probably fit with rolled fenders but it's really too big for a 9" rim. Don't know for sure of course, because I would not run or recommend offsets that low.
Old Jan 31, 2007 | 03:38 PM
cabaynes's Avatar
Old and grumpy
My disclaimer: I'm basing all this off of JimLab's FD Wheel/Tire Sizing guide, so I'm not claiming to be an expert on this... But according the the chart:
If you run a 17x8 +37 up front with a 225/45 the tire will have 0.45" of clearance to the fender.
Now 225mm = 8.858" and 235mm = 9.251", a difference of 0.393" so in theory a 235/40 *should* fit
If you run a 17x9 +37 in the rear with 255/35 the tire will have 0.45" of clearance to the fender.
Now 255mm = 10.039" and 275mm = 10.826", a difference of 0.787" so that doesn't look like it would fit... but 265mm = 10.433" so thats a difference of only 0.394" so technically that *should* fit as a 265/35
If you want to run a 275 you'll definitely have to roll and maybe pull, but running a 235/40 and 265/35 looks to be your best option
Old Jan 31, 2007 | 08:54 PM
ryenberg i will always seek ur opinion because i know u will always give the right or correct decision. i went against u but i never said u was wrong..ur not on my bad side thank u both for ur help!
Old Jan 31, 2007 | 10:51 PM
treceb's Avatar
ownage. just kiding bro.
hmm my car doesnt look that bad from afar. still can see them blue silicone spots.
ohh yea. get them rims on already.lol
Old Jan 31, 2007 | 10:58 PM
Eggie's Avatar
I'm not saying the 275s will fit, but I think you missed on the calculation. The tire may be .787" wider, but only 1/2 of that is on the fender side of the wheel's centerline.
Old Feb 1, 2007 | 04:53 AM
r u gonna donate paco?
Old Feb 1, 2007 | 07:54 AM
cabaynes's Avatar
Old and grumpy
You're right, I wasn't even thinking about that when I posted. I guess both of my calculations are a bit off then. I would still stick with the 235/40 and the 265/35 though just so you don't have to destroy your fenders... I've got a friend making well over 400hp on 265's just fine.
Old Feb 1, 2007 | 09:44 AM
treceb's Avatar
i got like a spare $50 on my paypal account...or you can have the tires on the MS01s. as a matter of fact if i have time ill go unmount them saturday. i think theyre 235/40 and 255/35.
Old Feb 1, 2007 | 11:35 AM
NeoTuri's Avatar
The shy megalomaniac
I personally wouldn't try 275s with any offset less than 40
Old Feb 1, 2007 | 12:01 PM
Zebb's Avatar
I run (on the street) 17x8 +35 (235/40-17) front and 17x9 +34 (265/40-17) rear. This is how it looks like in the front:
Very high setting :P
Fully compressed (almost)
Still very/almost fully compressed.
There are even more space at the rear so i dident bother taking more pictures. I hope this helps.
Old Feb 1, 2007 | 04:42 PM
rynberg's Avatar
Stock suspension cars can get away with less offset.....
Old Feb 1, 2007 | 04:46 PM
Zebb's Avatar
Tein Flex, stock fenders, no rolling etc...
Old Feb 1, 2007 | 07:02 PM
damn not rollingwitht that set up thats uspriseingly nice mabe i dont have to roll mmuch
Old Feb 1, 2007 | 07:04 PM
zebb lets see pics of the rear!!!
Old Feb 1, 2007 | 07:32 PM
rynberg's Avatar
You run those Teins pretty damn high, doesn't even look lowered.
Old Feb 1, 2007 | 09:34 PM
i think the firt picthe wheel was turned thats wh the car looked lifted the 2nd and 3rd pic look low as hell to me
Old Feb 1, 2007 | 10:27 PM
treceb's Avatar
those rims on zebbs car look like mazdaspeeds, plus i think those are the offsets on my mazdaspeed of the same size and they fit good.
Old Feb 2, 2007 | 08:28 AM
Zebb's Avatar
The car is not on the ground, thats why it looks high + the pictures are taken from below. I can take more pics later today if you want me to... I can test different offsets using spacers. So if you guys want to know if some kind of strange offset will work or not, now is the time to ask. I can only test with the Mazdaspeed and the OEM wheels/tires.
I will be running 17x9 (+27,3) on the track with 235/610(~36) -17" slicks front and rear this summer. Thats the setup they use in STCC (swedish touring car championship) and i got them from one of the teams. The offset is a little extreme but i dont need to roll my fenders or anything.
Old Feb 2, 2007 | 02:57 PM
yea can u get pics of the rear
Old Feb 5, 2007 | 03:09 PM
Zebb's Avatar
Ok, i was wrong, the rear is pretty tight, perfect i would say. You could easily fit 285/35 with rolled fenders.
unloading the spring
Lifting the wheel...
Depending on suspension stiffness you might never compress the dampers this much...
Front
Front again
Old Feb 5, 2007 | 05:12 PM
i love the way they look but i think u should clip/roll ur rear fenders
Old Feb 6, 2007 | 10:05 AM
Zebb's Avatar
Maybe, but why? I havent had any problems yet...
Old Feb 7, 2007 | 01:59 PM
fdeeznutz's Avatar
White is tight
I used to have the Mazdaspeed wheels like Zebb.
235-40-17 in front ruined my front fenders (bent and paint chipped)
275-40-17 needed about 1/8 inch shaved off my rear fenders to fit.
Eibach lowering springs, stock struts.
Old Feb 7, 2007 | 02:13 PM
i just thought they would rub a lil but if not ur good
Logan Reinisch
44
Sep 17, 2018 12:20 PM
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
eplusz
15
Oct 7, 2015 04:04 PM
TeamRuffRacing
Sep 30, 2015 08:13 PM
