Brake warning light
Old Jan 29, 2007 | 02:19 PM
kgray's Avatar
GOT WANKEL?
Brake warning light
The warning light went off. I searched and found that it could lead to low brake fluid(mine is fine),
Parking brake on(mine is off),
too far pedal travel(mine is inconsistant from great to weak),
Bad MC(no idea on mine's age-- only $30)
Frozen caliper(rolls fine in Neutral)
I will re-bleed and flush MC tonight and report back, but do you have any other ideas on what to check?
Thanks,
KGray
Old Jan 29, 2007 | 02:20 PM
Nicholas P.'s Avatar
Thanks,
KGray
When that sensor in the master cylinder gets low it goes off. I would check for a loose connection.
Old Jan 29, 2007 | 03:42 PM
DriftFB's Avatar
Reno Rotary.
if the brake warning light is off your in good shape. You don't want it on while your driving.
Old Jan 29, 2007 | 04:25 PM
kgray's Avatar
GOT WANKEL?
by went off i really mean lit up. lol like saying "the alarm went off" sorry for the confusion. any ideas other than the sensor connection?
Old Jan 29, 2007 | 05:40 PM
trochoid's Avatar
Old Fart Young at Heart
Are all of your brake lights working?
Old Jan 29, 2007 | 06:05 PM
Keegan's Avatar
that is what my car did i just fixed the old dead brake light and it was fine
Old Jan 29, 2007 | 09:53 PM
kgray's Avatar
GOT WANKEL?
all (as in one light on each side) are working. one of my side markers is out, but has been. Bled at the master and no air bubbles. I can double check connections, but everything looked fine when i bled. any other ideas?
Old Jan 30, 2007 | 02:45 PM
kgray's Avatar
GOT WANKEL?
Bump. It was cold outside today and the light went away until the car warmed up and now it is back on.
Old Jan 30, 2007 | 03:20 PM
Rx-7Doctor's Avatar
Verify that the float portion of the sensor is not stuck in the down posistion.
Old Jan 30, 2007 | 08:21 PM
Cascadia's Avatar
Seattleite-moss optional
It used to be (not sure if it is in our cars) that a brake warning light would come on if there was a pressure differential between the front and rear brake systems. That would usually indicate a leak in the lines somewhere. As long as there was equal pressure, the switch would not be activated, and the brake warning light would remain off.
Old Jan 30, 2007 | 09:23 PM
kgray's Avatar
GOT WANKEL?
the float is at the top, so no indication there, will check for leaks and stuck caliper/drum next.
Old Jan 30, 2007 | 09:34 PM
trochoid's Avatar
The light will come on if the float is too low in the master, or there is a wiring fault.
Old Feb 2, 2007 | 06:30 PM
kgray's Avatar
GOT WANKEL?
OK i'm puttting a new MC in right now, but how do i get the brake fluid resivoir off? it is driving me nuts!
Old Feb 2, 2007 | 07:09 PM
ray green's Avatar
Gone
Could it maybe be that your emergency brake cable is sticking a little in the cold weather, lets go when it warms up?
Old Feb 2, 2007 | 07:11 PM
ray green's Avatar
Gone
Oh yeh, to get the master cylinder off you need to undo two nuts on the cabin side of the fire wall, up near where the brake pedal lever pivots. Also all those brake lines of course.
Ray
Old Feb 2, 2007 | 07:18 PM
kgray's Avatar
GOT WANKEL?
what about the actual fluid resivoir? how do i get it off of the old MC?
Old Feb 2, 2007 | 08:18 PM
ray green's Avatar
Gone
um, I'm not sure if you can, it might be sealed to the cylinder. But why take that off, I thought you were replacing the master cylinder. They usually come with the res attached.
Old Feb 2, 2007 | 08:47 PM
kgray's Avatar
GOT WANKEL?
nope, with this one i had to re use it. it came off, but one of the nipples broke off. Do you know where i can get one with the res. attached? O'reilly doesnt have it, but BD does. i might run up there tomorrow. I need one ASAP tho.
Thanks for all of your help;.
fastsaab
Aug 19, 2015 11:42 AM
