Just a quick warmup question.
Old Jan 28, 2007 | 07:56 PM
clbsinvaders's Avatar
www.ohiorotaries.com
Question: how long should I let my 1984 GSL-SE warm up in both this cold weather (ohio winter...don't worry, I just want to know, i don't drive it much at all.) or in the summertime? I can't find anything about it in the manuals.
Old Jan 28, 2007 | 08:00 PM
Jeezus's Avatar
Stu-Tron Get Yo Groove On
I dont know if the 12a and 13b are a HUGE difference in warm up styles... Me personally, I let it sit and warm up for atleast a minute before I drive off, to get the "blood" flowing. After that minute, I keep it no more than 2500 rpm until it is completely warm. Had no problems.
Old Jan 28, 2007 | 08:12 PM
3rd and final 7's Avatar
wheres the water goin?
you can ket it warm up for4 about a min and then drive but dont go over 4000 rpm until you get to normal running temp!
Old Jan 28, 2007 | 08:56 PM
trochoid's Avatar
Old Fart Young at Heart
It comes down to common sense. Long warmup periods contribute to more carbon buildup due to the richer fuel conditions when cold. High rpms when the oil is still cold and thick can lead to accelerated internal wear.
With the engine in good tune, one can usually start and go, keeping the rpms under 3-4k. In extremely cold weather a bit more warm up time is needed not only for the engine oil but also for the tranny lube so shifting is easier.
Old Jan 28, 2007 | 09:03 PM
woodonastick's Avatar
my fb is older than me
i like way trochoid just said. i personally dont let it sit for awhile only because i have a fat oil leak. wat i do is i start the car...let it build oil pressure and just go. i shift at 3-3.5k rpm max till the choke is back in. then i let hell loose.
Old Jan 28, 2007 | 09:51 PM
Rx-7Doctor's Avatar
And for the tranny lube I recommend synthetic to combat that notchy feeling that you get with regular gear oil in cold weather.
My Se's I have always started and went. I check to see that oil pressure is up and then drive it accordingly until it warms up.
Old Jan 29, 2007 | 10:00 AM
Okay, so just start up, and keep it under 3k?
Old Jan 29, 2007 | 10:14 AM
Exactly what I do. Once the pressure is where it should be I take off.
Old Jan 29, 2007 | 03:49 PM
DriftFB's Avatar
Reno Rotary.
I let it sit until the temp needle gets to where its obviously moved, about halfway through the very bottom reading and then go. Its normally 1-2 minutes, but I only do this in the winter when it gets down to -20 at night.
Old Jan 29, 2007 | 09:33 PM
I'm not sure how cold it gets here, but it's pretty low. It sits inside anyway, but it still gets pretty cold.
Old Jan 29, 2007 | 10:15 PM
Nicholas P.'s Avatar
2 minutes.
1 minute for startup and another for keeping it at 2000rpm. "If 12a".
Old Jan 30, 2007 | 10:20 AM
PercentSevenC's Avatar
I need a new user title
I just let it warm up until it'll idle on its own. (Crappy carb.)
Old Jan 30, 2007 | 11:38 AM
I'm 13B, gsl-se
Old Jan 30, 2007 | 11:48 AM
if its an automatic choke 13b then just let it idle for a minute. After a minute you can drive it just baby it some untill its warmed up.
Logan Reinisch
44
Sep 17, 2018 12:20 PM
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
vish86
Interior / Exterior / Audio
Oct 1, 2015 11:53 PM
TeamRuffRacing
Sep 30, 2015 08:13 PM
