Which clutch to buy for your car.. so many types! "Video"
Old Jan 23, 2007 | 03:22 AM
Nicholas P.'s Avatar
I found a really good video describing which clutches do what. Why a pressure plate has those metal spikes inside the circle.
Its good for a clutch newbie like me, I figured other newbies would like it.
-nick-
Click here to see Video
Old Jan 23, 2007 | 09:42 AM
dj55b's Avatar
informative enought for a thumbs up from this clutch noob too .. thanks
Old Jan 23, 2007 | 10:39 AM
MattG's Avatar
MattG FTW!!!!!
WOW!!! That is some good info right there! Thats great timing too as I am in the market for a new clutch!
Old Jan 23, 2007 | 10:47 AM
dj55b's Avatar
See without this video, from what i was informed, any pack type clutch is not meant to be street driven. Nice to know that you can get the 4 puck with kevlar to work good on street. Also wasn't sure about the puck type heat dissipation idea. I still don't understand that one. If the pucks are constantly rubbing against the flywheel, how does it really cool? Wouldn't cutting slots into the flywheel (to act like a slotted rotor) work better? as air is then getting inbetween the flywheel and the clutch pack, to actually cool the pack down? Or in other words since brakes and clutches are really doing the same thing, how would having 4 brake pads help reduce the off the rotors?
Anyhelp there would be great. Thanks
Sam
Old Jan 23, 2007 | 11:13 AM
ZeikHunter's Avatar
The Baxter
that was really very informative, especially when they touched on flywheels
Old Jan 24, 2007 | 01:53 AM
Sam
I guess since it it is grabbing stronger. In that time it takes it to grab it spins over a spot but the spot gets a breif second of cooling but with a all around circle it would just cause constant friction.
Kind of like rubbing your hand up and down your arm as fast as you can it gets a breif moment of not hurting. But with arm to arm... I guess.
-nick-
Old Jan 24, 2007 | 01:54 AM
Talking
This is the one he was showing with 4 puck kevlar.
http://www.fidanza.com/3point2.aspx
It even sais 84 RX-7 under the applications
http://www.fidanza.com/Files/clutchappguide.pdf
Old Jan 24, 2007 | 02:07 AM
OnlyOnThurs's Avatar
TACOCAT
very awesome!
cristoDathird
28
May 30, 2019 08:47 PM
Th0m4s
Feb 26, 2019 02:04 AM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
