Sponsored by: CARiD
Engine stand
Old Jan 17, 2007 | 07:21 AM
luism12lm's Avatar
Question Engine stand
Hello guys.
I’m looking to buy an engine stand to worn on my car. Now my question is does any one know how much a 13B engine weight? I was looking at a 750 lb. Engine Stand and I want to know if it is enough before I buy it.
Thank you,
Luism12lm
Old Jan 17, 2007 | 08:01 AM
Rocking Rotary's Avatar
A fully dressed 13brew is about 350 so any engine stand should hold it. Also you will need to a adapter to mount the engine to the stand.
Old Jan 17, 2007 | 02:20 PM
luism12lm's Avatar
How about the locknut that secures the flywheel, what side is it? I was told a 38 will do.
Old Jan 17, 2007 | 02:29 PM
Dan H's Avatar
Zoom Zoom Boom!
54mm or 2 1/8th socket
Or was it 52m?? I forget but all you need is a 2 1/8th socket. You can get it at Sears for about $25.
Old Jan 17, 2007 | 02:36 PM
luism12lm's Avatar
Question
Thank you Dan H. What other special tool do you think I will need to open the engine?
Luism12lm
Old Jan 17, 2007 | 03:03 PM
Mahjik's Avatar
Mr. Links
Arrow
Flywheel stopper (to aid in removing the e-shaft bolt and the flywheel nut):
http://www.mazdatrix.com/toolmisc.htm
Old Jan 17, 2007 | 03:04 PM
Its 54mm. YOu wont need anything else to take it apart but you may need a few to have it put back together with new stuff. Like the press for the bearings, pilot bearing remover, micrometer, dial indicator and all that jazz.
Old Jan 17, 2007 | 08:35 PM
Pele's Avatar
Right near Malloy
You don't really need that if you've got an impact wrench.
Otherwise, a piece or bar with two holes drilled in it, bolted to the clutch holes works well. Just turn till it braces against the engine stand, the wall, the floor, or yourself.
Old Jan 17, 2007 | 09:38 PM
Mahjik's Avatar
Mr. Links
I've got an impact wrench and I still need it (or something else). Granted, mine isn't some 1000 ft/lbs wrench but it couldn't budge the e-shaft bolt.
Sure, you can always rig up something. But for a $20 some odd dollar tool, why not?
FD7KiD
15
Feb 26, 2021 10:12 PM
astrum
24
Nov 15, 2017 08:44 AM
FD7KiD
Aug 17, 2015 11:50 PM
Engine stand ready
Aug 14, 2015 10:26 PM
