Jdm
Old Jan 15, 2007 | 07:36 PM
kevinpowers's Avatar
Jdm
im going to buy a jdm turbo motor off of ebay. 1500 seems like a good deal, but i was wondering what year motor i should get? i have a 86 n/a but they have motors all the way up to 89. any suggestions?
Old Jan 15, 2007 | 07:46 PM
turboefini88's Avatar
Long rifle.
I wouldnt do that. If your interested in getting a turbo engine, buy one from the forums or from one of the reman companies. I have heard nothing but horror stories about the "JDM" engines off ebay. Most importers do not offer even start garuntees on rotaries they import. Kinda tells ya something
Old Jan 15, 2007 | 07:51 PM
stevensimon's Avatar
yeah you can find a rebuilt us turbo motor for around 1k on here. you want an s4 motor to make life a little easier. 87-88 years. to make it even easier get an 87-87.5 motor with the low impedance injectors
Old Jan 15, 2007 | 08:06 PM
well ****, they say they have 15 day startup warranties and they have been compression tested, and are guranteed to run. where do i find a used one on here?
Old Jan 15, 2007 | 08:11 PM
kinda gettin discouraged, i dont have that much money to play with here, damn cars are expensive for a 11th grader
Old Jan 15, 2007 | 09:15 PM
Long rifle.
I never seen one on Ebay that offered a warranty or been compression tested or even like that on a true importers website. Got links?
Old Jan 15, 2007 | 09:21 PM
RXJIM's Avatar
15 days isn't a lot of time to do a N/A to turbo conversion, even harder to go S5 turbo.
Old Jan 15, 2007 | 09:36 PM
agreed..
check the parts for sale section for a motor.
Old Jan 15, 2007 | 09:58 PM
i dont have the link most of the jdm sellers said 15 days and comp tested. is it that hard to do a n/a to turbo swap?
Old Jan 15, 2007 | 10:02 PM
http://cgi.ebay.com/ebaymotors/JDM-1...spagenameZWDVW
this one doesnt say anything about compression testing but if i bought one this is what i would get
Old Jan 15, 2007 | 10:25 PM
KhanArtisT's Avatar
Former FC enthusiast
http://cgi.ebay.com/ebaymotors/JDM-M...QQcmdZViewItem
This one has a one month warranty, a bunch of the ones I've seen before have a 90 day warranty.
Old Jan 15, 2007 | 11:08 PM
V8slayer's Avatar
Tire Smoken Tandm Gambler
talk to japan2la he has some real good jdm motors i got one from him and its ben running strong
Old Jan 16, 2007 | 12:08 AM
cool ima talk to him
Old Jan 16, 2007 | 12:35 AM
MaczPayne's Avatar
Mac Attack
How much money do you have to work with? If you just have enough for a motor, you're going to need more.
Have a series 4 RX-7? Get a series 4 engine to save yourself alot of wiring headache.
Likewise with the series 5's.
Old Jan 16, 2007 | 01:19 AM
KompressorLOgic's Avatar
I
your probbaly better off buying a real t2, if you dont know what your doing.( as i sure didnt at that age) haha
after a few yrs of ******* around with rx7, i could do a swap blindfolded haha
Old Jan 16, 2007 | 02:55 AM
dsmrx7's Avatar
Yeah, I bought a JDM S5 Engine from Ebay. It came with EVERYTHING that I needed to drop into my RHD RX7 Shell (this shell came with no wires, nothing but rust and metal). The bad news, it's got really low compression on the Front Rotor. Otherwise, I'm another step closer to completing this "Project."
Old Jan 16, 2007 | 04:29 AM
ibekinq's Avatar
just needing a few things
man whatever you do, DO NOT order from these guys. they hae a place down here in dallas and in new jersey i bought 2 sr20 rom them and they gae me problems. 1 motor was broke main crank was in two and gave me wrong ecu's for both motors. all their motors sit for months to years before some one buys em. these guys i delt with were also *** holes that try to
Old Jan 16, 2007 | 08:49 AM
FelixIsGod29X's Avatar
Manual Rack
DONT NOT BUY A JDM OFF EBAY! I bought an S4 T2 jdm off ebay and they said it had SOLID compression......F No! Soon as i get it i checked the compression and 2 of the rear apex seals where stuck. (either carbon build up or flatten springs. Im just gonna get new apex seals and the cheap overhaul gasket kit and tear the whole thing apart. Im pissed because I know i could have gotten something better from this site.
Old Jan 16, 2007 | 08:56 AM
lupin's Avatar
Rupanrx
why get a turbo motor?
Just get a standalone and a turbo with intercooler and a exhaust mani that mates up.
It might not have as much power as a s5 T2 engine but it will be a hell of a lot easier to do.
Old Jan 16, 2007 | 12:08 PM
im thinking of buying one off of japan2la off this site . ive read hes sells pretty legit motors. i sent him a message and he says hes got one in stock that has good compression 1250 for motor and tranny but a cut harness. what does it mean if it got a cut harness?
Old Jan 16, 2007 | 05:14 PM
That Rx-7 kid's Avatar
car fanatic
tell me about it.......
Old Jan 16, 2007 | 06:31 PM
djmtsu's Avatar
DGRRX
That is a good deal.
A cut harness means you will need a TII engine harness, and you will still need an ECU, AFM, boost sensor, maybe a few other things (unless you go without emissions )
Remember you cannot use the TII trans with the N/A driveshaft. You can get one that will go from the TII trans-> N/A differential from Mazdatrix. Or you can put your N/A flywheel on the TII engine and use all the N/A driveline until you get everything together.
Be sure to find out what all you will get:
-Does the trans still have the starter?
-Slave cylinder?
-What sensors/accessories are on the engine?
-Does he have an ECU?
Find out as much as you can.
Good Luck!!!
DJ
Old Jan 16, 2007 | 06:52 PM
yeah cheap way out is to use na tranny and flywheel on the t2 motor.. and hopefully by the time the trans bites it, you will have the money to utilize the stronger turbo trans. so with that motor you will need a us spec s4 turbo harness, computer, afm, knock box, boost pressure sensor and fuel pump
Old Jan 16, 2007 | 07:56 PM
MaczPayne's Avatar
Mac Attack
If you have an s4 car, get an s4 engine. Get an s5 and you will have to deal with compatibility issues. That's what I did, and now I'm using a standalone.
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
distr0
Canadian Forum
Oct 7, 2015 08:17 AM
