Turbo ? Please help
Old Jan 15, 2007 | 06:33 PM
Turbo ? Please help
So I've got a stock t2 turbo in my garage that i picked up from an auction and i want to use it. I need to get a gasket for between the turbo and the down pipe. My only problem is im not sure if it's a s4 turbo or a s5 turbo. Is there any differences or any way i can tell witch one is witch thanks. Jeremy
Old Jan 15, 2007 | 07:05 PM
Turbo II's Avatar
It's only Rock and Roll
s4 from 86 through 88 and s5 is 89 to 91 model years, what year is your car?
Old Jan 15, 2007 | 08:06 PM
I bought the turbo used and i don't know what year it came off of. I was wondering if maybe i could tell by looking at it??
Old Jan 15, 2007 | 08:12 PM
danec020's Avatar
Several ways to tell, one is the S5 hotside is larger because it has a dual wastegate. Also the wastegate arm is a little bent. Also the exhaust flange is square, the S4 exhaust is a little more rounded... I think that is pretty much it...
To sum it up look for the dual wastgate, if its there then its a S5.
Dane
Old Jan 15, 2007 | 08:13 PM
speed_monkey's Avatar
affen
Thats my s5 turbo.
Old Jan 16, 2007 | 12:57 AM
awesome thanks guys!
Old Jan 16, 2007 | 07:14 AM
7dust's Avatar
Irregular Here
Gasket from the turbo to the downpipe is the same - S4 and S5.
The turbine housing has a different footprint on the exhaust manifolds but the mating surface to the downpipe is the same configuration.
Old Jan 16, 2007 | 07:51 AM
RETed's Avatar
Originally Posted by speed_monkey
Thats my s5 turbo.
Too bad it's not stock and useless to this thread.
S4 versus S5 turbine inlet flange...
-Ted
Old Jan 16, 2007 | 09:18 AM
7dust's Avatar
Irregular Here
Does it really matter what series it is?
Same downpipe gasket for either one.
Old Jan 16, 2007 | 10:05 AM
riverzendz's Avatar
Interruptor Illuminada
When mounting it to an exhaust manifold it matters.
Old Jan 16, 2007 | 11:44 AM
7dust's Avatar
Irregular Here
Mr Griffith apparently wants to stop his downpipe from leaking - not remove the turbo.
Old Jan 16, 2007 | 01:10 PM
affen
-Ted
o haha I accidentally posted a pic of the t04e instead of my stock turbo. :p
Old Jan 16, 2007 | 04:48 PM
Brody8877's Avatar
#FakeCarEnthusaist
For the turbo manifold it matters, but for the DP it is all the same between s4 and s5.
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
