Interesting dilemma.
Old Jan 13, 2007 | 09:31 PM
$100T2's Avatar
On the prowl for an FB
So, I bought a T2 a month or so ago. It was originally a Canada car.
I have no use for KMs.
Therefore, my question is, can I swap in a speedometer/odometer from a US car? I have one in my basement... Can I undo the gauge cluster, take out the KM/H speedo and odometer and switch in the MPH unit?
Old Jan 13, 2007 | 10:18 PM
$100T2's Avatar
Where's Icemark when you need him?
Old Jan 13, 2007 | 10:32 PM
misterstyx69's Avatar
Retired Moderator, RIP
good question..and $100T2 I know you aren't lookin for a Guess,But I am going to..YES..and for the Reason that if they were Manufacturing for different Parts of the world and had to Swap Tranny Speedo **** all the Time it would have Cost a bit to Mazda..the cluster Reads KPH..and They always had a Little sticker when they first started Conversion..Way back to put over your Speedo..100 KPH=60 MPH ,30 MPH =50KPH..(mph times .6 ,and Kph times 1.6)...Know it doesn't Really answer the question but the logic says yes..the Speedo cable is spinnin at the Same Ratio.
Old Jan 14, 2007 | 12:25 AM
Black91n/a's Avatar
Should work, but consult with the DMV first on the legality of changing out an instrument cluster (odometer issues), and be sure to document it thoroughly.
Old Jan 14, 2007 | 12:33 AM
Mankdrake 2661's Avatar
Mazda goes MMMMMMMM
The DMV doesn't usually care about odometer readings anymore. All you got to write on the title is that the reading is "beyond the mechanical limit." I think that's what it's called. Besides alot of cars that are 20 years old have already flipped the odometer over.
Old Jan 14, 2007 | 08:39 AM
hIGGI's Avatar
simple question, simple answer.....YES
Old Jan 14, 2007 | 10:50 AM
Aaron Cake's Avatar
Engine, Not Motor
Just swap the gauge faces. The cluster stays the same so the odometer will be correct but will read in KM instead of miles. Might be a problem, might not.
Old Jan 14, 2007 | 10:57 AM
$100T2's Avatar
Well, my MPH odometer just happens to be within 500 miles of the KM conversion, so that's why I was thinking of just flipping 'em.
finishline's Avatar
Not Even Foo
if only i could do the same with my JDM cluster i got sitting in my house... wanted that stock boost gauge look. but im sure it's different because the battery gauge exists there instead. oh well. guess its just gonna sit in my room as decoration.
Old Jan 14, 2007 | 10:58 AM
Icemark's Avatar
just swap the clusters... they are the same
Old Jan 14, 2007 | 12:34 PM
turboeric's Avatar
I expect that varies by jurisdiction, so I'd still want to check. A used car dealer here was just convicted on several counts of fraud for swapping instrument clusters from lower mileage wrecks so that his beater inventory looked more attractive.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Cameron38
1st Gen General Discussion
Sep 19, 2015 11:45 PM
