No Boost Help
Old Mar 11, 2002 | 10:51 AM
Willie's Avatar
No Boost Help
1995 RX-7 with only 33K miles. No boost shown at any RPM on gauge. 1200 RPM idle, and slighty "poppy" sounding. Looking at the turbo diagram, its looks like I should start with the Wastegate and actuator ? Hope its not the turbo itself..
Thanks for any advise !
Willie
AND THE ANSWER IS A BLOWN INTAKE GASKET.. ORIGIONAL ONE IS A PAPER COMPOSIT, AND EVERYTHING INCLUDING THE TURBO NEEDS TO COME OFF TO FIX IT.. BIG $$$$$
WILLIE :-<
Old Mar 11, 2002 | 11:13 AM
Bucrx7's Avatar
Do you hear any hissing sound? If not then check the vacuum line that goes from the back of your upper intake manifold to your map sensor, which is bolted to a bracket on the firewall near the master cylinder.
Old Mar 11, 2002 | 11:32 AM
ttpowerd's Avatar
HARRRRRRRRR
might just need to replace your hoses...boost leak!
Old Mar 11, 2002 | 11:35 AM
Willie's Avatar
No Hissing sound . Will try what you suggest.
Thanks
Shainiac
Jul 17, 2019 02:20 PM
Bauer778
Nov 4, 2015 04:42 PM
zxrazorxz
Sep 14, 2015 07:21 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
