Custom Length Spark Plug Wires
Old Dec 30, 2006 | 05:59 PM
7-sins's Avatar
thats not paint....
I am trying to relocate my ignition coils out from on the block. I still want to keep cruise, so I am thinking where the battery use to be, or somewhere around there. I have been reading on the forum about custom length plug wires and ran into a lot of dead links & old info. It seems like going with a wire kit & crimping the ends yourself is the way to go.... knowing me I would probably screw them up & dont you need a crimp tool? also are they just as reliable as wires premade? Another option was 2nd gen plug wires? People say they seem to work for the cruise location, but I dont know how long they are, or if they will reach to where the battery was. Anyone else done this? Pics would be sweet too.
Thanks guys,
Chris
Old Jan 2, 2007 | 04:55 PM
7-sins's Avatar
thats not paint....
bump...
Old Jan 2, 2007 | 05:03 PM
DaleClark's Avatar
RX-7 Bad Ass
FC plug wires are quite long. The leading coil on the FC is by the battery, and the trailing coil is where the cruise is on an FD.
You can make your own, but you really need a GOOD crimping tool to do the job right. You could totally get a set of plug wires for the cost of making them and buying the tool. If you want some to experiment with, get some FC plug wires from the junkyard or from the 2nd gen FS forum for cheap. That will give you an idea.
Dale
Old Jan 2, 2007 | 06:19 PM
badddrx7's Avatar
All Spooled Up
Relocating the coils ? Not a problem, Contact these guys and they will fix you up with what you need. Get the 10mm R-100 high temp red wires. They ROCK !!
http://www.magnecor.com/
Old Jan 2, 2007 | 07:02 PM
GARCO MOTORWORKS's Avatar
I make my own wires so I bought the tools .I have been useing 8mm MSD 40 ohm wire for several years on my car ,with 4 coils and my customers cars,with no failures .The wire comes in 25 foot rolls .
Old Jan 3, 2007 | 05:41 PM
7-sins's Avatar
thats not paint....
Thanks guys, I guess I will look for a trashed pair of 2nd gen wires first. If that doesn't work maybe Ill find out the length I need & contact magnacore.
I was hoping to add this onto my huge summit order but I guess it can wait.
Old Jan 3, 2007 | 06:58 PM
EZFD's Avatar
i bought the Accel universal set for a V8 and they seemed to work out fine plus you get 2 sets of 8mm spark plug wires for about $60
The1Sun
Mar 18, 2018 11:08 PM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
Snoopy FD
Dec 8, 2015 01:45 PM
PhillyFC
Aug 21, 2015 06:36 PM
