Twins: How to tell seq or non-seq?
Old Dec 22, 2006 | 08:28 AM
tphan's Avatar
Physically, is there a way to eye whether a set of sequential twins that has been modified as non-sequential?
Old Dec 22, 2006 | 08:39 AM
dopefishlives's Avatar
Grand Poobah of Torque
Yes.
The actuator for the secondary turbo exhaust feed could be manually wired open, or if the actuator has been completely removed. Also typically the butterfly in the Y-pipe is either wired open or completely removed and the holes are filled in.
_Kris
Old Dec 22, 2006 | 08:42 AM
MR_Rick's Avatar
Planning my come back
If they have done a full non-seq conversion, there will be a lot less vaccum hoses around. With the poor man non-seq conv. you can look for a door under the car that will be wired open. For both way you can also see if they have a BOV a CRV. If there is both then they will be hooked up to the same source of vaccum since they are both a BOV. In some case there will be no CRV.
Old Dec 22, 2006 | 08:54 AM
tphan's Avatar
pickup a set of low mileage twins last night and noticed the actuator for secondary was missing...triggering my question.
Thanks.
ls1swap
Jun 3, 2024 03:25 PM
Romeoxray7
Power FC Forum
15
Nov 20, 2015 01:38 AM
Toadman
11
May 26, 2002 07:16 PM
