Shits and Giggles - T51rKAI Spool vs GT35r Spool (by hand)
Old Dec 10, 2006 | 12:04 AM
dhahlen's Avatar
FD Under Construction =P
***** and Giggles - T51rKAI Spool vs GT35r Spool (by hand)
This is a video of how a ball bearing turbo spins vs a journal bearing.
For all of those that are curious to see the difference in spool time without the turbo being run.
The KAI is the huge one of course... and the GT35r is ball bearing.
A 35r will spin for about 30 seconds after the car is shut off, where as the KAI stops spinning in about a second or two.
Click here to see Video
Old Dec 10, 2006 | 12:14 AM
charlies7's Avatar
3rd rotors a charm
**** that turbo on the left looks kinda familiar
Old Dec 10, 2006 | 01:15 AM
CarbonR1's Avatar
Even for a journal bearing, the turbo spins unusually slow. Are you sure that there is lube inside?
Old Dec 10, 2006 | 01:23 AM
dhahlen's Avatar
i didn't put in oil in it, only has 1k miles on it
the other gt35r needs a rebuild
Old Dec 10, 2006 | 03:13 AM
CarbonR1's Avatar
try lubing it up a bit, it should definitely spin better than that. What's wrong with the 35R?
Old Dec 10, 2006 | 03:32 AM
dhahlen's Avatar
I bought it that way knewing it needed a rebuild
Old Dec 10, 2006 | 09:53 AM
Turblown's Avatar
Turn up the boost
Without oil under pressure, or any heat in there that isn't a real life comparison. Funny how I see BB salesmen doing the same thing at tradeshows..
Rotary Performance Parts
Old Dec 10, 2006 | 11:23 AM
dhahlen's Avatar
Thats why I said for ***** and giggles
Old Dec 10, 2006 | 11:33 AM
BuffDaddy915's Avatar
Tha ladies man
Charlie..was that ur old turbo?? Would this be the reason I didn't do 2 shabby when we raced?
Old Dec 10, 2006 | 11:43 AM
charlies7's Avatar
3rd rotors a charm
lol JJ, yes this is the reason. I was only running 10psi and i was still pulling on you a lil on that first race. . What were you spiking to. Ill have a little something for you come spring time
Old Dec 10, 2006 | 11:44 AM
dhahlen's Avatar
Yeah charlie said it 'wasn't that bad' - his original picture wasn't... but after running it unbalanced and being a bit torn up.. you can see how it damaged it further.
Old Dec 10, 2006 | 11:46 AM
charlies7's Avatar
3rd rotors a charm
now that the turbo is in good hands ill be able to see what she can do come spring time!!
Old Dec 10, 2006 | 04:37 PM
c00lduke's Avatar
My wheel looked like that also, probably worse even. I was wondering why my spool seemed laggy.
Old Dec 10, 2006 | 07:20 PM
dhahlen's Avatar
Yeah no reason a t3 gt35r shoudl spool slow. Even on stock ports, you should see boost come on around 2800, and full by 33-3500 rpm. Or so I hear... I remember guitarjunkie's car at 10lbs, that thing came on so fast.. it was nuts.
Old Dec 10, 2006 | 07:46 PM
Marcel Burkett's Avatar
When I bought my 3071R's they would spin when I put them in front of the fan , now that they are on the car they continue spinnning for more than a minute after the engine is shut off.
Old Dec 11, 2006 | 05:00 PM
IRPerformance's Avatar
Sponsor
Send it to majestic. I've sent 3 of these their way and they are able to set it straight.
Old Dec 11, 2006 | 05:08 PM
LUPE's Avatar
My old T51R KAI would spin for 30-45 seconds after the car would shut off.
Old Dec 18, 2006 | 08:03 PM
Turblown's Avatar
Turn up the boost
Just bustin' your *****
Old Dec 18, 2006 | 11:23 PM
dhahlen's Avatar
LOL
Figured you dig up this post after our phone conversation.
Old Dec 20, 2006 | 10:16 AM
GUITARJUNKIE28's Avatar
multipersonality disorder
guitarjunkie was at 4000ft elevation too
oddly, my t66 only spools like 100-150 rpm slower than the old 35r, but it's got more turbine, so it's a little more friendly at higher boost levels on pump gas.
Old Dec 26, 2006 | 04:01 PM
Railgun's Avatar
I won't let go
Veteran: Marine Corp
It WAS in good hands before even you got it.
That thing sure got around.
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
eplusz
15
Oct 7, 2015 04:04 PM
Einheri
Oct 7, 2015 12:23 PM
