another 20B question for ya...
Old Mar 8, 2002 | 10:18 AM
Aaronhil's Avatar
Newbie
Ok, lets just say for the sake of it that I want to put a 20BTT in my FD. I am going to have to replace the entire front wiring harness (goes from the ECU, through the nose of the car, and back to the fuse panel) due to some extensive damage.
If I were to buy the 20B, stock 20B ECU, could I buy a wiring harness designed for a 20B and adapt that into the FD? Could that possibly eliminate the other engine management problems that are part of the conversion?
This is just PURE speculation since I doubt I will have the money when that time comes so please keep the flames low.
Old Mar 8, 2002 | 04:19 PM
More Power's Avatar
Why not post this in the 20B forum. You could try searching that forum first. There is probably info on it in there.
Old Mar 9, 2002 | 03:41 AM
peejay's Avatar
Old [Sch|F]ool
"It's your swap. You can do any damn thing you want"
99% of the time, when you do an engine swap, you don't buy wiring harnesses. You make them.
Old Mar 9, 2002 | 08:12 AM
rxrotary2_7's Avatar
off to the 20b section.
Old Mar 9, 2002 | 08:41 AM
RETed's Avatar
Re: another 20B question for ya...
NO.&nbsp The stock Cosmo ECU integrates the stock automatic transmission into it.&nbsp Unless you FOOL the stock ECU into thinking the stock automatic transmission is back there, it's going to check and fail-safe on you.&nbsp This also implies you're going to run the stock ignition coils?&nbsp These are very hard to get, as the are not attached to the engine - they are mounted on the left-side fender areas.&nbsp The harness that runs to the coils is not attached to the main wiring harness.&nbsp This is all possible if you got a Cosmo 20B front cut, but I have never heard anyone being able to pull this off...
-Ted
Old Mar 9, 2002 | 06:40 PM
black99's Avatar
Lurking..................
There was a NZ guy who said he had gotten a 20b conversion to work with the stock ecu, but I have no idea how, and I don't think he posted how..
Old Mar 11, 2002 | 01:56 PM
j9fd3s's Avatar
Community Builder
they do have some fix for the ecu down under. i would suggest e mailng the guy(s) at www.3rotor.com
the problem with the wiring harness is that there is only 1 harness. they only have the harness to put the 20b in the cosmo, anything else will have to be custom.
the cosmo harness does fit in an fc.
by doing the swap this way you will still have headaches with the ems, but they will be different than everyone elses.
mike
Old Mar 11, 2002 | 07:41 PM
now's Avatar
now
3rotor.com a great site! but i don't think anyone ever replies to email! at least i have never gotten a reply(
matt
Old Aug 10, 2004 | 01:18 PM
Black_91_GT's Avatar
bump
Old Aug 10, 2004 | 09:07 PM
RETed's Avatar
Check with Corksport for reprogram so stock ECU ignores auto trans.
-Ted
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
