running methanal
Old Nov 13, 2006 | 08:51 PM
eivad1's Avatar
home of the 64oz
Lightbulb running methanal
can u get power running methanal on a carb n/a motor
Old Nov 14, 2006 | 08:59 PM
eivad1's Avatar
home of the 64oz
bump
Old Nov 15, 2006 | 12:44 AM
ikari899's Avatar
engineer wanabe
yes but its not worth it
Old Nov 15, 2006 | 03:41 AM
eivad1's Avatar
home of the 64oz
can i ask y is it the cost of buying it and what r the pros n cons
Old Nov 17, 2006 | 10:28 PM
eivad1's Avatar
home of the 64oz
ding dong
Old Nov 18, 2006 | 01:51 PM
ikari899's Avatar
engineer wanabe
oh sorry its because methanol is used mainly for its cooling ability and knock resistance in turbo motors. you really wont see any performance increases on a carbed NA motor. yes it does have the potential to add hp but not in the ways that it does on a turbo motor.
Old Nov 21, 2006 | 08:26 PM
riceburner1r2001's Avatar
ty ikari now i understand clearly
Old Nov 21, 2006 | 09:33 PM
13btnos's Avatar
Please do some research before you make a comment. Plenty of high horsepower PPorts are running alcohol. To name a few Jesus "Kilo" Padilla, Ken Scheepers, Rene Franco, Travieso and quite a few others. https://www.rx7club.com/rotary-drag-racing-167/rene-rx-7-10-5%40124-all-motor-598653/
https://www.rx7club.com/rotary-drag-racing-167/travieso-racing-10-21%40130-video-597910/
I wouldn't do it with a carb, fuel injection would be much more appropriate for alcohol use.
Old Nov 22, 2006 | 01:52 PM
speedturn's Avatar
The latest issue of Circle Track magazine has a good article talking about all the extra maintenance you are required to do just to clean the Methanol out of the fuel system between races in order to prevent it damaging components.
Old Nov 22, 2006 | 06:09 PM
ronbros3's Avatar
I dont think you can get enough compression ratio to make it really worthwhile in a rotary, maybe fill in the rotor chambers! most good Methanol engines run 14-16-1 ratio , if you can get an N/A engine to start to go into detonation, with proper ign. timing,then you may get Methanol to help. 87 octane has more heat energy per Lb. than a lot of other fuels except Diesel fuel. just some thoughts on your idea.Ron
Old Nov 22, 2006 | 09:01 PM
ikari899's Avatar
engineer wanabe
aggressive now are we? trust me i know what im talken about, sorta
any way i was under the assumption they run pure alcohol, not just inject it. and if you did read my post i did say there are horsepower gains to be made with alochol/meth though further cooling the intake charge and allowing for more aggressive ignition timing. BUT i was saying that in this case with a carb'd street motor the amount of money he would spend would be much better spent some were else, in my opinion. which is further helped by the above 2 posts.
so dont get all uppity about it :P
Originally Posted by 13btnos
Please do some research before you make a comment. Plenty of high horsepower PPorts are running alcohol. To name a few Jesus "Kilo" Padilla, Ken Scheepers, Rene Franco, Travieso and quite a few others. https://www.rx7club.com/showthread.php?t=598653
https://www.rx7club.com/showthread.php?t=597910
Old Nov 22, 2006 | 09:04 PM
ikari899's Avatar
engineer wanabe
lol are you being serious or mocking me
cause if you want some more info ask and i will see what i can do. or ill find it for ya
Old Nov 23, 2006 | 02:50 AM
crispeed's Avatar
'Tuna'
Yes you can and that's speaking from actual experience.
Now there are many different techniques that can be put into use to even further benefit from the use of alcohol/methanol as the main fuel even if it's done with a carb.
The main benefit off course is to take advantage of it's cooling effects may it be by tuning and engine building techniques.
C. Ludwig
Jan 30, 2019 06:31 AM
Rotospectre
Mar 28, 2018 03:33 PM
turbo-minivan
69
Feb 4, 2016 12:29 AM
The Shaolin
Sep 14, 2015 07:50 PM
