What is the right way to build your rx-7.?.
Old Nov 13, 2006 | 02:00 PM
Rhythm n Flow's Avatar
Talking What is the right way to build your rx-7.?.
hey wazup, i juz want to get sum advise from the rx7 people on how to properly build a good turbo II engine for the street and for drift without the motor blowin out on me... rght now i have racing beat turbo exhaust system, apexi intake system, hks bov, greddy tubo timer, koyo radiator and thatz it for performance parts... i juz want to get a good 310hp or sumwhere around that... lyke what should i do next... what brand parts would you recommend and what is good 2 get... well let me kno thanx
Old Nov 13, 2006 | 02:12 PM
drewl's Avatar
Flame Thrower
for drift you need more suspension work than motor work. if you do upgrade turbo, don't get a huge turbo for huge power, cuz you get huge lag as well. get a smallish turbo for quick spool, torque on demand is where it's at.
Old Nov 13, 2006 | 02:16 PM
gingenhagen's Avatar
I am 2Furious
Here's a starting point for you.
http://www.fc3spro.com/TECH/DRIFT/dori.html
http://www.fc3spro.com/TECH/FM2W/fm2w.html
Old Nov 13, 2006 | 02:19 PM
rx7 FC TII's Avatar
Semper
for turbos i suggest BNR Turbos here is a link to his websitehttp://bnrturbos.com/
Edit: i suggest for drifting you save up and purchase some nice coilovers
Old Nov 13, 2006 | 02:34 PM
NOPR's Avatar
Rotary Apprentice
do you have a full exhaust or just a cat back? do you speak english?
Old Nov 13, 2006 | 04:07 PM
miyagi's Avatar
+1 on coilovers
w/ a TII, you have enough power to get sideways. Build up the suspension and steering first, learn good steering and throttle control and then increase the power. I've got a bad motor in a stock gxl and I can still drift it while keeping the revs under 4k [on blacktop and wet pavement]
Old Nov 13, 2006 | 04:29 PM
drewl's Avatar
Flame Thrower
if i was going to build a bare-minimum fc drift car, i'd have mid-level coilovers, stock clutch type or welded open diff, and spaced steering rack. if you are/know/can find a good welder, relocate the tie rod mounting points on the spindles. this is really good bang for buck mod.
Old Nov 13, 2006 | 05:24 PM
miyagi's Avatar
quick question and not meaning to threadjack...but which model fc came w/ a clutch type? i thought they were all viscous
Old Nov 13, 2006 | 05:27 PM
adrock3217's Avatar
Boost in..Apex seals out.
^^^ All S4's had clutch type, or, the ones that had them. (GTU, T2, etc)
S5's had viscous.
Old Nov 13, 2006 | 05:36 PM
adrock3217's Avatar
Oh and. If I were to build a drifting T2, with my few garage tools (no welder):
First of all, a compression test. Make sure your engine is healthy before spending any money on it, PLEASE. I hate seeing people cry about spending so much money, only to find out there engine is on the way out.
STANCE coilovers (very cheap, very nice), with solid suspension bushings, ABSOLUTELY you must eliminate the DTSS (rear steer bushings), or you will have some major snap-oversteer issues...
Pull the turbo, tear down the block, replace all gaskets, fluids, etc with all fresh, spark plugs and wires, basically a MAJOR overhaul / maintenence endeavor.
Get the turbo's wastegate ported. Theres no telling how much damage you've already done by not having this done (from your list of mods). If it's an S4, get rid of the twin scroll and port out the manifold.
Full intake, exhaust, Megasquirt, boost controller (12psi), 720cc secondary injectors, walbro fuel pump. re-wired fuel pump mod, port-matched manifolds, a healthy set of gauges, just little things that make a difference.
All of this can be done for roughly $3000-4000...yet it is very effective. You can do more suspension work, but the bushings and coilovers will have the most impact on your car as far as being able to predict exactly what it will do, and doing it square. With 12psi on the stock turbo, with a good tune, you will be making around 245-260rwhp, which is more than enough to throw it around, probably more than you'll need at this point.
I'd always reccomend starting off in an NA car..so you can actually learn to drift, and not just punch the throttle and hope..
Old Nov 13, 2006 | 06:26 PM
breckboarder55's Avatar
big port + big turbo=
First off go back to school... Second invest in a nice fuel managment system... Third, tune, tune, and tune...
Old Nov 13, 2006 | 06:32 PM
snowball's Avatar
I live in the lounge...
+1 english FTW.
Old Nov 13, 2006 | 07:02 PM
drewl's Avatar
Flame Thrower
don't you know? purposefully mispelling words is the new english. i'm not cool enough to play that game though.
at least the grammar is *mostly* there. i've seen much worse.
Old Nov 13, 2006 | 07:36 PM
RX7Tuner.'s Avatar
I really Schruted it
Why write "Thanx" when you could simply write, "Thanks"? I'll never understand...
Old Nov 13, 2006 | 10:28 PM
Pookie's Avatar
^ One time I wrote "thanx" because my pen was running out of ink...
Old Nov 13, 2006 | 10:35 PM
MazterDizazter's Avatar
I'm your turbo lover
"What is the right way to build your RX-7?"
"What is the meaning of life?"
I see some similarities here...
RedBaronII
Sep 20, 2015 11:29 AM
