Where to get porting done
Old Nov 13, 2006 | 10:52 AM
FCKing1995's Avatar
Rotary Slave
Im looking for a place to do a port job for me. Im thinking either a street port. Would it be necissary to have a half bridge done if Im only looking to run a BNR Stage 3 and an Rtek 1.8. Eventually I will go larger turbo and maybe stand alone, so thats why Im sorta wanting a half bridge. Plus the ricer in me likes the idle Im not too worried about losing a bit on the bottom end as long as it will pull mid-top. So back to the main question. Anybody know of a good place to send them to? Preferably in either the east or south, no northwest or anything like that if I can help it. Want it to be semi local to Alabama.
Old Nov 14, 2006 | 07:33 AM
FCKing1995's Avatar
Rotary Slave
Also, about lapping irons. Everything Ive heard about this, is that lapping the irons takes off the outer most layer, forget what its made of. Isnt removing that layer bad, since itll make it wear out faster? Cause it looks like most reputable rebuild places do this when rebuilding. If I rebuild and dont see any major gouges or scratches, can I get away without doing any lapping or no?
Old Nov 14, 2006 | 08:40 AM
RotorHead87's Avatar
Cosmo 13B-RE
I think the shop I'm about to refer is abit out of your range. The shop JR Fabrication and Performance is building my Cosmo 13B-RE as of now and two other FC's one with a 13B-REW and the other with an RE. I have seen the shops other projects and theyre built with quality labor. Not sure if this is helpful to you but I tried just give J.R. a call (the number in my signature), and also I beleve he has a buddy in Alabama that works on rotaries. I forgot what the shop was called though. Anyways good luck with your project!
Old Nov 14, 2006 | 08:51 AM
Aaron Cake's Avatar
Engine, Not Motor
A bridgeport will not run on the RTek very well, and you don't "need" it since you can make 600+HP on a streetport "easily". However the port will spool some very large turbos and pull like hell over 4K. Myths of lack of low-end are just that. That BNR turbo is too small for a bridgeport.
Lapping is only necessary when the iron is out of spec. And the S4+ irons can only be lapped a few times before the groove for the water o-ring becomes too shallow.
Old Nov 14, 2006 | 10:21 AM
FCKing1995's Avatar
Rotary Slave
SO for a BNR Stage 3, a mild streetport would be good enough, I plan on running about 12-14psi? Also, if i check my irons and they are out of spec and have them lapped, that wont affect the life of the engine will it? I swear I read somewhere that lapping them messes up the coating on them and they wont last nearly as long. Or did I hear wrong?
Old Nov 14, 2006 | 12:15 PM
Turblown's Avatar
Turn up the boost
I wouldn't run a hybrid turbo on a ported engine, you're going to be choking on that tiny turbine side, even if you opt to have a P trim stuffed in there...
Rotary Performance Parts
Old Nov 14, 2006 | 12:40 PM
FCKing1995's Avatar
Rotary Slave
Well Im only running a hybrid for now. Down the road I will be going stand alone and probably a 60-1 turbo or something similar. Im only porting when my engine goes, or if it hasnt gone within a year or so Ill just tear it down anyway and do a full build
Old Nov 14, 2006 | 05:53 PM
Kyrasis6's Avatar
MazdaTruckin.com Founder
I don't think the irons are coated, the inside of the rotor housings are plasma sprayed with chromium or something like that. Lapping the inside of those would remove some or all of the layer.
Old Nov 14, 2006 | 06:00 PM
FCKing1995's Avatar
Rotary Slave
Perhaps thats what I was thinking. My fault
Old Nov 15, 2006 | 07:40 AM
My5ABaby's Avatar
Rotaries confuse me
Chrome.
Old Nov 15, 2006 | 08:02 AM
HAILERS's Avatar
HAILERS
The lapping and the porting can be done by Pinnapple Racing. I've never had anything done by them ...yet.
One reason I think they might be a good place, is I've recently seen their online site which has videos of different aspects of engine building etc and I think it's a *cool* site.
http://rotaryengineillustrated.com/home/index.php
Old Nov 15, 2006 | 08:35 AM
FCKing1995's Avatar
Rotary Slave
Well mainly I wanted to know where to have Bridge porting done. I can have a street port done just up the street by BNR
Old Nov 15, 2006 | 08:58 AM
Aaron Cake's Avatar
Engine, Not Motor
The irons are nitrided to harden them. The housings are chrome plated.
Anyone who can do a street port can do a bridge port.
Old Nov 15, 2006 | 09:04 AM
FCKing1995's Avatar
Rotary Slave
yeah, I wasnt sure but i guess like you said, bridge isnt really needed. So why not just go with a street port
Old Nov 15, 2006 | 10:12 AM
HAILERS's Avatar
HAILERS
Who does bridgeporting? HERE: http://www.pineappleracing.com/ProdSvcs1.html
Also I suspect BDC on the other forum does bridgeporting.
Old Nov 15, 2006 | 10:45 AM
Sideways7's Avatar
Yeah, BDC definately does bridgeporting. He's on this forum too, just not as much as the other one.
Old Nov 15, 2006 | 12:38 PM
snowball's Avatar
I live in the lounge...
BDC does bridgeporting? no way!
Old Nov 17, 2006 | 07:22 PM
AlexG13B's Avatar
brap brap brap
Question
I was actually thinking of doing the same (running halfie with a BNR stage 3) but i guess after reading your post i might have to rethink it..
what do you recccomend to run? nothing outrageous..
what price ranges roughly (including downpipe, wastegate, & exhaust manifold)?
BTW BDC IS THE MAN at half/full bridges.
Old Nov 17, 2006 | 07:26 PM
Sideways7's Avatar
I've never seen a streetported motor get 600 HP easily. The most I recall is J-rat's, which is 490 using alchy injection. Granted he has more room to go with a better turbo, but its not exactly easy.
A half bridge, from everything I have read (plus talking with Brian/BDC) will help spool the turbo faster at lower rpms. The BNR is definately too small for it though.
Old Nov 17, 2006 | 07:33 PM
FCKing1995's Avatar
Rotary Slave
Isnt J-Rat stock port?
Old Nov 17, 2006 | 07:38 PM
AlexG13B's Avatar
brap brap brap
yes he is stock port. stock ports can handle some good power also, i guess im in it more for the BRAP BRAP BRAP.....
Old Nov 17, 2006 | 07:55 PM
FCKing1995's Avatar
Rotary Slave
heh, so am i. not saying all i want is sound, i want power too, but i could handle losing some bottom end for the sake of having that beautiful idle best sound ever. id sit in my car and listen to it idle for hours when i got bored
Old Nov 17, 2006 | 08:01 PM
RXJIM's Avatar
Bdc+1
Old Nov 17, 2006 | 08:03 PM
876portturbo's Avatar
getcha brap on
BDC
Old Nov 17, 2006 | 09:06 PM
AlexG13B's Avatar
brap brap brap
ya I spoketo BDCalready,he is def.porting my stuff
