stuck 5th port actuatior
Old Nov 12, 2006 | 10:15 PM
manslayerx9's Avatar
as the title says the part in the lim is whats actually stuck. i tried wd-40 and it will move if i hit it with a hammer and screw driver lightly but it wolnt move by hand. so what should i do??
Thanks
Jason
Old Nov 12, 2006 | 10:27 PM
arghx's Avatar
rotorhead
you gotta pull the manifold
Old Nov 12, 2006 | 10:38 PM
chano's Avatar
All Rotor
do you mean the conecting rod? if yes, its probably rusted,so you need to take the lim out, cut the rod and hammer the crap out of it till comes out .of course, you will need another one.
if you mean the actuator itself , just buy a used one in working condition from someone in the forum. dont waste your time trying to fix it.
Old Nov 12, 2006 | 10:42 PM
Valkyrie's Avatar
Funny thing, mine both started moving immediately after I removed the manifold...
Also, you should try to move the actuators with the vacuum hoses taken off... sometimes the pressure will make them seem like they don't want to move.
Old Nov 12, 2006 | 10:57 PM
Sideways7's Avatar
If they suddenly moved once you removed the LIM, the the aux port sleeves (the things in the motor) were stuck. You will need to remove them and clean them up to get them working properly. From my experience, if one of the three things (rod, actuator, or sleeve) stick then one or both of the other two tend to stick over time since they aren't moving.
Old Nov 13, 2006 | 01:02 AM
well when i pullde it apart there were no sleeves in the ports so do u think that is why they were left out. and should i put them back(the sleeves) or just leave them out??
Old Nov 13, 2006 | 11:14 AM
Valkyrie's Avatar
Actually they weren't stuck at all... I had already cleaned them when I took the motor apart (they were original black, they turned back to silver with a little polishing).
When I pulled them apart last time, they were still clean, and were completely lubed up from the OMP and stuff. Which confused the crap out of me... but now I'm pretty sure they move (although I haven't confirmed they're actually working, because that's a bit harder...).
Old Nov 13, 2006 | 11:48 AM
slpin's Avatar
7th Heaven
wd40 will collect dirt...
ZacMan
Sep 19, 2015 09:20 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
teebeekay
Sep 16, 2015 01:54 PM
Josh83rx7
Sep 15, 2015 10:23 AM
