Can the hatch itself squeak?
Old Nov 12, 2006 | 06:19 PM
drft_180sx's Avatar
Mine seems to squeak when the opposite wheels are on different heights (entering a driveway that is elevated, in reference to the street, at a 45 degree angle - meaning the front left wheel is on the driveway and the rear right is still on the street, with the other two somewhere in the middle).
I was reading the "RX-7" book by some japanese guy and it said the hatch is basically a steel skeleton with a huge piece of curved glass. And that the skeleton was used to strengthen the structure. My hatch doesn't seem to have any rust, but my hatch shocks have failed a while ago (it holds up the weight, but doesnt spring the hatch open when the lever is pulled/key is turned).
The thing has been getting louder and louder over the past 3-4 months. As far as mods go i have switched to much stiffer sidewalled tires, which make the ride more rough, but nothing else. What would be the cause, how can i fix it?
Jahan
Old Nov 12, 2006 | 06:41 PM
I have same problem with my FC.
To stop squeaking hatch, I placed window weather stripping rubber under black vents located on both upper sides of hatch opening.
Old Nov 12, 2006 | 08:03 PM
Black91n/a's Avatar
Vaseline.
Rub it all over the seal and it should improve things.
Old Nov 12, 2006 | 08:15 PM
fc3sna's Avatar
make sure its closed all the way
Old Nov 12, 2006 | 08:21 PM
Sgt. Pepper's Avatar
My hatch rattles to ever since I put on my KYB AGX and Tanabe GF210's. It seems to only rattle from the passenger side of the hatch.
Old Nov 12, 2006 | 08:23 PM
drft_180sx's Avatar
THanks for the advice, will try soon! and let you guys know
Old Nov 21, 2006 | 10:26 PM
ZeroDrift's Avatar
Any updates on the hatch noises?
Old Nov 22, 2006 | 07:14 AM
My5ABaby's Avatar
Rotaries confuse me
Jack Yamaguchi is the author. ISBN 0-312-69456-3 for anyone interested (good read).
Icemark mentioned that Yamaguchi wrote 2 more books on the FC but I can't find them. Anyone know the other 2?
Old Nov 22, 2006 | 07:13 PM
I found that book at my library and checked it out. Pretty good, nice fullpage pictures to.
Old Nov 23, 2006 | 03:00 AM
drft_180sx's Avatar
UPDATE!!!!!
vaseline on the hatch rubber seals have not solved the problem. It seems like the problem is getting worse as the weather gets colder...
Old Nov 23, 2006 | 07:03 AM
hIGGI's Avatar
check points where hatch is connected to shell, both lower/upper, they are making noise usually, on stiff cars and bad roads, they could get loose
Old Jan 29, 2007 | 04:05 PM
endneu913's Avatar
Turbo Waggin
OMG, i had that same problem and i tried everything! I could have sworn it was teh rubber squeeking like crazy, sounded like birds in my hatch! turns out it was the latch mechanism.... it gets cold and just needs some lube.....! try it........
izzolaw
1st Gen General Discussion
Sep 27, 2015 08:33 PM
