starting problem...please help :(
Old Nov 12, 2006 | 04:07 PM
mali_FC's Avatar
oops......speed bump....
my car can not start, when I turn the ignition key the car loses electrical power - everything dies. ...you can only hear warning beep, but fading away..
I have new battery, new terminals, the fuses are fine, I've just replaced alternator and starter.
I'm thinking of ECU and CPU boxes
thank you in advance guys...
Old Nov 12, 2006 | 04:33 PM
Icemark's Avatar
dead battery or loose battery terminals
Old Nov 12, 2006 | 05:36 PM
HAILERS's Avatar
HAILERS
I'm thinking about how you just changed the starter and might not have installed the gnd wire on the LONG starter bolt good. THAT wire on the LONG starter bolt is the main gnd for just about everything in the long run.
Or the new battery cable end fittings just are not on good.
I'm betting the lotto that the ECU and CPU have squat to do with your problem.
Old Nov 12, 2006 | 05:58 PM
mali_FC's Avatar
It's weird ...I just bought a new battery so it can't be that.
the terminals are new and not loose.
I checked everything that I did last on it....it doesn't make any sense.
Old Nov 12, 2006 | 06:11 PM
RXnos1200's Avatar
1200 gone......but......
I've gotten some new batteries for our customers' cars that were too weak to start a car. Never know how long they are sitting on the shelf before they are sold. Get a bettery tester and give it a load test.
Old Nov 12, 2006 | 06:22 PM
mali_FC's Avatar
I hope that's the issue..... I was able to start it with a jumper cables...I didn't hold it long and when I shut the engine off I wasn't able to turn it back on.
Old Nov 12, 2006 | 06:41 PM
RXnos1200's Avatar
turn on the headlights and try starting it. if it goes dim then I'd say that the battery has some issues. good luck.
Old Nov 12, 2006 | 06:59 PM
mali_FC's Avatar
I lose electrical power as soon as I turn the ignition.....
Old Nov 12, 2006 | 07:05 PM
RXnos1200's Avatar
battery has issues
Old Nov 12, 2006 | 07:07 PM
RXnos1200's Avatar
get another battery from one of your friend's car and see what happens.
Old Nov 12, 2006 | 11:30 PM
mali_FC's Avatar
I replaced my battery with another one (new) and same problem occurs.
....I'm really confused now..
Old Nov 13, 2006 | 07:50 AM
My5ABaby's Avatar
Rotaries confuse me
+1
I had brand new battery cables on my car and they didn't work for crap (don't get the painted ones).
Old Nov 13, 2006 | 09:03 AM
HAILERS's Avatar
HAILERS
His battery cables are the problem. Either at one end OR the other.
He really NEEDS to do what is asked of him. HE was asked to turn his headlights on and give the results. He did not. He turned his key to On and said he loses electrical power. HE did not do what was asked. TURN THE HEADLIGHTS ON and tell the man what you observe. NOT turn the key to ON. TURN THE HEADLIGHTS ON.
Did they come up? Did the stay bright?
Old Nov 13, 2006 | 09:14 AM
My5ABaby's Avatar
Rotaries confuse me
Originally Posted by My5ABaby
+1
I meant battery terminal connectors.
Old Nov 13, 2006 | 10:06 AM
RXnos1200's Avatar
check the ground wire too. make sure the one going to your block or trans is making good contact.
Old Nov 13, 2006 | 12:41 PM
mali_FC's Avatar
It seems like anything I try to turn on in my car loses power and dies...
I already tried to turn the lights on, and they did not work.
Old Nov 13, 2006 | 08:15 PM
RXnos1200's Avatar
double post for some reason.
Old Nov 13, 2006 | 08:18 PM
RXnos1200's Avatar
was everything working before you replaced the starter and alternater and terminals? seems like there is a bad connection somewhere. seems more like on the positive side. check the wire to the alternator again and make sure it has a good connection. check the battery with a volt meter and see what you get. check and see if your getting good voltage at your fuse box. grounds ok? check the one going to the engine or trans. what part of los angeles? I am in culver city/ marina del rey right by Washington Blvd. & Lincoln Blvd. PM me. J.
Old Nov 13, 2006 | 09:51 PM
mali_FC's Avatar
what I noticed was that the alternator was charging poorly, ......I tested the alternator today and it was bad..... when I put a spare one in it has the same problem, the car won't start
Old Nov 13, 2006 | 09:56 PM
RXnos1200's Avatar
how did you test it if it won't start? or does it start now?
Old Nov 13, 2006 | 10:01 PM
mali_FC's Avatar
I took the alternator out and I tested it at Auto Zone....
Old Nov 13, 2006 | 11:08 PM
RXnos1200's Avatar
see you tomorrow. make sure that battery is charged before I get there.
Old Nov 13, 2006 | 11:20 PM
Shaughn's Avatar
Burn Rubber Not Your Sole
get the car jumped again and test the output voltage on the alternator and let me know what its reading
ZacMan
Sep 19, 2015 09:20 PM
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
