Flooded GLS-SE quicky question
Old Mar 4, 2002 | 08:15 PM
HOZZMANRX7's Avatar
Driving RX7's since 1979
Question GLS-SE quicky question
On a 2nd gen, you can simply pull the EGI fuse, turn the engine over a few times, replace the EGI fuse and your good to go.
Where is the EGI fuse on a GSL-SE? It doesn't look like it's one of the fuseable links.
Old Mar 4, 2002 | 08:59 PM
FJ's Avatar
FJ
There is no equivalent on the FB. There is an engine fuse under the dash, but...
If you disconnect the primary on the trailing (front) coil, it will prevent the fuel pump from running. (13B only, does not work for the 12a) If you hold it disconnected while someone turns it over, and reconnect it after a few seconds of turning, without stopping, it may do the trick. If not, remove the plugs, etc.
-John.
Old Mar 4, 2002 | 09:09 PM
HOZZMANRX7's Avatar
Thumbs up Thanks
Old Mar 4, 2002 | 09:47 PM
brownmound's Avatar
Anytime baby!
Pulling the engine fuse under the dash has always worked for me. Not that the Mound floods or anything...
Right on.
Old Mar 5, 2002 | 09:03 PM
rxseven's Avatar
Special Dark
it's the green fusible link. The block says "injectors". Pulling it out should disable the injectors
Old Mar 6, 2002 | 12:18 AM
FJ's Avatar
FJ
The only problem with pulling the link, as with the engine fuse, is that it will also disable the ignition.
The advantage with pulling the primary of the trailing coil is that it kills the fuel pump but the leading plugs will still fire. The engine will run for a second on the excess fuel and the remaining fuel under pressure in the line, drying the plugs and chambers better that just turning it over.
Plus it's easier to get at.
-John.
Old Mar 6, 2002 | 08:28 AM
MyRxBad's Avatar
EliteHardcoreCanuckSquad
Do a search.....This issue has been dealt with a million times with many solutions.
Old Mar 16, 2002 | 09:09 AM
-John.
this works perfectly... with the one coil disconnected the engine'll fire once, this is when to reconnect the coil. It'll then start pumping again and run fine.
I've installed a relay to do this for me... cold mornings don't get along with the engine too well, so it's needed sometimes.
_Tones_
May 25, 2021 05:37 AM
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
Monsterbox
Sep 11, 2015 03:29 PM
Nosferatu
Sep 5, 2015 02:13 PM
